Brief version: How can I debug my Chromebook woes when trying to run kernel-next with the Mali drivers?
I followed this guide: Graphics and Compute Development on Samsung Chromebook It worked, but I'm left with an incredibly unstable system. I'm running a Samsung Chromebook, model number SNOW FREMONT A-E 0878.
A list of stability issues so far:
I'm even sure there's more, but for now that should give a good idea of what's up: ridiculous instability. I might be able to throw the image on a USB drive and use a USB wifi adapter and skate by some of this, but that's really not a sufficient solution. Given that and the incredible unlikeliness that anyone here has already had or is having this issue, I'd really like it if someone could tell me how to debug these issues as I don't have any clue how to approach it. I have a bit of familiarity with the Linux kernel and a ton with C, but not a darn clue how I'd go about debugging Linux running on a Chromebook.
Hope this is related enough to be discussed here - I certainly don't know where else to discuss problems with this guide.
I had this issue long time back with external mmc. This problem was with 3.4 as well 3.8. Got really frustrated trying to fix it. I then finally decided to flash uboot and format internal mmc. I have put the steps in a blog post Bootloader unlock on samsung arm chromebook | kr blogs
Please note that its very dangerous and risky flashing uboot
Hmm... I'm certainly intrigued, but will it really solve my problems? I'm having issues with the MMC bus on only 3.8 - 3.4 stock with Chrubuntu works, and I can access the SD card just fine inside Cros, no signs of instability. However, even running off USB stick, excessive use of the SDIO WiFi device will cause my device to crash. (The crash leaves me at a screen with an empty VT, a non-blinking cursor at the top left, and the mouse cursor still on screen. I'm guessing that's just the result of a kernel panic happening.)
The hardware modifications seems a little more hardcore than I feel like risking. You can if you like run your own u-boot using the second bootloader method. I got it working, and you can read the steps I took here in this discussion as they differed from the "official" steps.
That said-- people seem to be building the mainline kernel instead of kernel-next, which I don't think anyone has checked changes into for two months. I'm wondering if this might be the way to go. (also see this thread) If no one gives it a try, I am thinking of giving it a shot by taking mainline, applying the patches, and then seeing what happens
ft
Update: Hmm, I'm not seeing much gpu support-- there's no /drivers/gpu/arm directory in mainline, making it kind of hard to do the changes to mali_kbase_config_chromebook.c, considering that file doesn't exist. Looks like framebuffer only. I added in the gpu driver and I'm trying to see if it can be shoehorned into place... but I invite anyone who might know more than I do to chime in. Can the mali open source device driver be dropped into 3.12?
