"Instruction failed texture-miss count"
hi everyone
i use streamline for Mali profiling
but i cant understand "Instruction failed texture-miss count"
And if failed texture-miss count  is high
what should i do to reduce "Instruction failed texture-miss count"
thanks!
  • Hi zhong,
    If your texture-miss count is high, this is usually because your textures are too large. Consider:
    • Compressing your textures with ETC (for Mali-400/450)
    • Using smaller resolution textures
    • Use mipmaps
    • Look for opportunities to use less channels, or channels with lower bitdepth. Do you really need RGBA8888?
    • Avoid 24 bit textures, stick to 16 or 32, for cache efficiency.
    Hope this helps,
    Chris
  • Hi zhong,
    • Use mipmaps
    Hope this helps,
    Chris
