OpenCL driver issue with Samsung Chromebook
I had an issue with the OpenCL Driver on my Chomebook.
I followed ARM's instruction and successfully boot into Linux. However, I got an error message said that libxcb-dri2.so missing. After install libxcb-dri2.0-dev, I can compile Mali OpenCL SDK sample codes. But they won't be executed correctly under X11 or via fbdev. I past error message below. Any suggestion? Thanks.
> ./hello_world_opencl
OpenCL error: CL_OUT_OF_HOST_MEMORY
Creating an OpenCL context failed. common.cpp:248
Failed to create an OpenCL context. hello_world_opencl.cpp:39
> ldd hello_world_opencl
        libOpenCL.so => /opt/mali/fbdev/libOpenCL.so (0x76efc000)
        libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0x76e4a000)
        libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0x76e39000)
        libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x76d55000)
        /lib/ld-linux-armhf.so.3 (0x76f07000)
        libmali.so => /opt/mali/fbdev/libmali.so (0x76304000)
        libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0x762e9000)
        libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0x7627e000)
        librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0x76270000)
        libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0x76265000)
  • Hi j.c.
    The SDK samples don't depend on libxcb-dri2 (the x11 mali driver does), so I cant explain why they won't compile natively until you install it. I've just tested both cross compilation and native compilation and both methods work for me and produce binaries, which run fine. (native compilation you simply edit platform.mk and remove the arm-none-linux-gnueabi- prefix. And also, to cross compile hard float, you must replace it with arm-linux-gnueabihf- if using the linaro toolchain, but I assume you already did one of these)
    My X11 libs are in /usr/lib so when i run ldd i get:
    $ ldd hello_world_opencl
            libOpenCL.so => /usr/lib/libOpenCL.so (0x764fd000)
            libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0x76455000)
            libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0x76444000)
            libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x76360000)
            /lib/ld-linux-armhf.so.3 (0x76f58000)
            libX11.so.6 => /usr/lib/arm-linux-gnueabihf/libX11.so.6 (0x7627b000)
            libX11-xcb.so.1 => /usr/lib/arm-linux-gnueabihf/libX11-xcb.so.1 (0x76271000)
            libdrm.so.2 => /usr/lib/arm-linux-gnueabihf/libdrm.so.2 (0x76260000)
            libxcb.so.1 => /usr/lib/arm-linux-gnueabihf/libxcb.so.1 (0x76246000)
            libxcb-render.so.0 => /usr/lib/arm-linux-gnueabihf/libxcb-render.so.0 (0x76238000)
            libxcb-dri2.so.0 => /usr/lib/arm-linux-gnueabihf/libxcb-dri2.so.0 (0x7622d000)
            libXext.so.6 => /usr/lib/arm-linux-gnueabihf/libXext.so.6 (0x7621b000)
            libXau.so.6 => /usr/lib/arm-linux-gnueabihf/libXau.so.6 (0x7620f000)
            libXfixes.so.3 => /usr/lib/arm-linux-gnueabihf/libXfixes.so.3 (0x76203000)
            libXdmcp.so.6 => /usr/lib/arm-linux-gnueabihf/libXdmcp.so.6 (0x761f7000)
            libXcomposite.so.1 => /usr/lib/arm-linux-gnueabihf/libXcomposite.so.1 (0x761ed000)
            libXrender.so.1 => /usr/lib/arm-linux-gnueabihf/libXrender.so.1 (0x761df000)
            libXrandr.so.2 => /usr/lib/arm-linux-gnueabihf/libXrandr.so.2 (0x761d1000)
            librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0x761c3000)
            libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0x761a8000)
            libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0x7619d000)
            libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0x76133000)
    My mali libs are in /root/malifbdev, so to get ldd for that I run:
    $ LD_LIBRARY_PATH=/root/malifbdev/ ldd hello_world_opencl
            libOpenCL.so => /root/malifbdev/libOpenCL.so (0x76f7d000)
            libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0x76ecd000)
            libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0x76ebc000)
            libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x76dd8000)
            /lib/ld-linux-armhf.so.3 (0x76f88000)
            libmali.so => /root/malifbdev/libmali.so (0x76387000)
            libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0x7636c000)
            libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0x76301000)
            librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0x762f3000)
            libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0x762e8000)
  • Hi j.c.
