Problems getting SurfaceTexture work with Android Videoplayer on MALI 400
Note: This was originally posted on 5th April 2013 at http://forums.arm.com
I've written an application which is rendering video into a texture basically using the code found as attachment.
This example works perferctly fine on a mobile device and on a tablet - both based on a Tegra. I've then tried the same code on a MALI 400 based android system (Minix Neo5) and I can see that the video plays but I get mainly a black screen with some garbage on it (just 3 or 4 lines)
public class VideoSurfaceView extends GLSurfaceView {
    VideoRender mRenderer;
    private MediaPlayer mMediaPlayer = null;
    public VideoSurfaceView(Context context, MediaPlayer mp) {
        super(context);
        setEGLContextClientVersion(2);
        mMediaPlayer = mp;
        mRenderer = new VideoRender(context);
        setRenderer(mRenderer);
        mRenderer.setMediaPlayer(mMediaPlayer);
    @Override
    public void onResume() {
        queueEvent(new Runnable(){
                public void run() {
        super.onResume();
    private static class VideoRender
        implements GLSurfaceView.Renderer, SurfaceTexture.OnFrameAvailableListener {
        private static String TAG = "VideoRender";
        private static final int FLOAT_SIZE_BYTES = 4;
        private static final int TRIANGLE_VERTICES_DATA_STRIDE_BYTES = 5 * FLOAT_SIZE_BYTES;
        private static final int TRIANGLE_VERTICES_DATA_POS_OFFSET = 0;
        private static final int TRIANGLE_VERTICES_DATA_UV_OFFSET = 3;
        private final float[] mTriangleVerticesData = {
            // X, Y, Z, U, V
            -1.0f, -1.0f, 0, 0.f, 0.f,
            1.0f, -1.0f, 0, 1.f, 0.f,
            -1.0f,  1.0f, 0, 0.f, 1.f,
            1.0f,  1.0f, 0, 1.f, 1.f,
        private FloatBuffer mTriangleVertices;
        private final String mVertexShader =
                "uniform mat4 uMVPMatrix;\n" +
                "uniform mat4 uSTMatrix;\n" +
                "attribute vec4 aPosition;\n" +
                "attribute vec4 aTextureCoord;\n" +
                "varying vec2 vTextureCoord;\n" +
                "void main() {\n" +
                "  gl_Position = uMVPMatrix * aPosition;\n" +
                "  vTextureCoord = (uSTMatrix * aTextureCoord).xy;\n" +
                "}\n";
        private final String mFragmentShader =
                "#extension GL_OES_EGL_image_external : require\n" +
                "precision mediump float;\n" +
                "uniform samplerExternalOES sTexture;\n" +
                "void main() {\n" +
                "  gl_FragColor = texture2D(sTexture, vTextureCoord);\n" +
                "}\n";
        private float[] mMVPMatrix = new float[16];
        private float[] mSTMatrix = new float[16];
        private int mProgram;
        private int mTextureID;
        private int muMVPMatrixHandle;
        private int muSTMatrixHandle;
        private int maPositionHandle;
        private int maTextureHandle;
        private SurfaceTexture mSurface;
        private boolean updateSurface = false;
        private static int GL_TEXTURE_EXTERNAL_OES = 0x8D65;
        private MediaPlayer mMediaPlayer;
        public VideoRender(Context context) {
            mTriangleVertices = ByteBuffer.allocateDirect(
                mTriangleVerticesData.length * FLOAT_SIZE_BYTES)
                    .order(ByteOrder.nativeOrder()).asFloatBuffer();
            mTriangleVertices.put(mTriangleVerticesData).position(0);
            Matrix.setIdentityM(mSTMatrix, 0);
        public void setMediaPlayer(MediaPlayer player) {
            mMediaPlayer = player;
        public void onDrawFrame(GL10 glUnused) {
            synchronized(this) {
                if (updateSurface) {
                    mSurface.updateTexImage();
                    mSurface.getTransformMatrix(mSTMatrix);
            GLES20.glClearColor(0.0f, 1.0f, 0.0f, 1.0f);
            GLES20.glClear( GLES20.GL_DEPTH_BUFFER_BIT | GLES20.GL_COLOR_BUFFER_BIT);
            GLES20.glUseProgram(mProgram);
            checkGlError("glUseProgram");
            GLES20.glActiveTexture(GLES20.GL_TEXTURE0);
            GLES20.glBindTexture(GL_TEXTURE_EXTERNAL_OES, mTextureID);
            mTriangleVertices.position(TRIANGLE_VERTICES_DATA_POS_OFFSET);
            GLES20.glVertexAttribPointer(maPositionHandle, 3, GLES20.GL_FLOAT, false,
                TRIANGLE_VERTICES_DATA_STRIDE_BYTES, mTriangleVertices);
            checkGlError("glVertexAttribPointer maPosition");
            GLES20.glEnableVertexAttribArray(maPositionHandle);
            checkGlError("glEnableVertexAttribArray maPositionHandle");
            mTriangleVertices.position(TRIANGLE_VERTICES_DATA_UV_OFFSET);
            GLES20.glVertexAttribPointer(maTextureHandle, 3, GLES20.GL_FLOAT, false,
            checkGlError("glVertexAttribPointer maTextureHandle");
            GLES20.glEnableVertexAttribArray(maTextureHandle);
            checkGlError("glEnableVertexAttribArray maTextureHandle");
            Matrix.setIdentityM(mMVPMatrix, 0);
            GLES20.glUniformMatrix4fv(muMVPMatrixHandle, 1, false, mMVPMatrix, 0);
            GLES20.glUniformMatrix4fv(muSTMatrixHandle, 1, false, mSTMatrix, 0);
            GLES20.glDrawArrays(GLES20.GL_TRIANGLE_STRIP, 0, 4);
            checkGlError("glDrawArrays");
            GLES20.glFinish();
        public void onSurfaceChanged(GL10 glUnused, int width, int height) {
        public void onSurfaceCreated(GL10 glUnused, EGLConfig config) {
            mProgram = createProgram(mVertexShader, mFragmentShader);
            if (mProgram == 0) {
                return;
            maPositionHandle = GLES20.glGetAttribLocation(mProgram, "aPosition");
            checkGlError("glGetAttribLocation aPosition");
            if (maPositionHandle == -1) {
                throw new RuntimeException("Could not get attrib location for aPosition");
            maTextureHandle = GLES20.glGetAttribLocation(mProgram, "aTextureCoord");
            checkGlError("glGetAttribLocation aTextureCoord");
            if (maTextureHandle == -1) {
                throw new RuntimeException("Could not get attrib location for aTextureCoord");
            muMVPMatrixHandle = GLES20.glGetUniformLocation(mProgram, "uMVPMatrix");
            checkGlError("glGetUniformLocation uMVPMatrix");
            if (muMVPMatrixHandle == -1) {
                throw new RuntimeException("Could not get attrib location for uMVPMatrix");
            muSTMatrixHandle = GLES20.glGetUniformLocation(mProgram, "uSTMatrix");
            checkGlError("glGetUniformLocation uSTMatrix");
            if (muSTMatrixHandle == -1) {
                throw new RuntimeException("Could not get attrib location for uSTMatrix");
            int[] textures = new int[1];
            GLES20.glGenTextures(1, textures, 0);
            mTextureID = textures[0];
            checkGlError("glBindTexture mTextureID");
            GLES20.glTexParameterf(GL_TEXTURE_EXTERNAL_OES, GLES20.GL_TEXTURE_MIN_FILTER,
                                GLES20.GL_NEAREST);
            GLES20.glTexParameterf(GL_TEXTURE_EXTERNAL_OES, GLES20.GL_TEXTURE_MAG_FILTER,
                                GLES20.GL_LINEAR);
          * Create the SurfaceTexture that will feed this textureID,
          * and pass it to the MediaPlayer
            mSurface = new SurfaceTexture(mTextureID);
            mSurface.setOnFrameAvailableListener(this);
            Surface surface = new Surface(mSurface);
            mMediaPlayer.setSurface(surface);
            surface.release();
            try {
                mMediaPlayer.prepare();
            } catch (IOException t) {
                Log.e(TAG, "media player prepare failed");
            mMediaPlayer.start();
        synchronized public void onFrameAvailable(SurfaceTexture surface) {
            updateSurface = true;
        private int loadShader(int shaderType, String source) {
            int shader = GLES20.glCreateShader(shaderType);
            if (shader != 0) {
                GLES20.glShaderSource(shader, source);
                GLES20.glCompileShader(shader);
                int[] compiled = new int[1];
                GLES20.glGetShaderiv(shader, GLES20.GL_COMPILE_STATUS, compiled, 0);
                if (compiled[0] == 0) {
                    Log.e(TAG, "Could not compile shader " + shaderType + ":");
                    Log.e(TAG, GLES20.glGetShaderInfoLog(shader));
                    GLES20.glDeleteShader(shader);
                    shader = 0;
            return shader;
        private int createProgram(String vertexSource, String fragmentSource) {
            int vertexShader = loadShader(GLES20.GL_VERTEX_SHADER, vertexSource);
            if (vertexShader == 0) {
                return 0;
            int pixelShader = loadShader(GLES20.GL_FRAGMENT_SHADER, fragmentSource);
            if (pixelShader == 0) {
                return 0;
            int program = GLES20.glCreateProgram();
            if (program != 0) {
                GLES20.glAttachShader(program, vertexShader);
                checkGlError("glAttachShader");
                GLES20.glAttachShader(program, pixelShader);
                GLES20.glLinkProgram(program);
                int[] linkStatus = new int[1];
                GLES20.glGetProgramiv(program, GLES20.GL_LINK_STATUS, linkStatus, 0);
                if (linkStatus[0] != GLES20.GL_TRUE) {
                    Log.e(TAG, "Could not link program: ");
                    Log.e(TAG, GLES20.glGetProgramInfoLog(program));
                    GLES20.glDeleteProgram(program);
                    program = 0;
            return program;
        private void checkGlError(String op) {
            int error;
            while ((error = GLES20.glGetError()) != GLES20.GL_NO_ERROR) {
                Log.e(TAG, op + ": glError " + error);
                throw new RuntimeException(op + ": glError " + error);
    }  // End of class VideoRender.
}  // End of class VideoSurfaceView.
[size=2]
[/size]
I've tried to use the OpenGL ES tracer to check what is copied from the SurfaceTexture back to the texture itself but it looks like the Tracer cannot show it correctly (neither on the tegra systems nor on the tegra devices. Note that I don't get any OpenGL error nor any warnings whatsover. It looks like everything is working fine.
Is there any other tool that can show me what if anything is copied to the TEXTURE_EXTERNAL ? All TEXTURE_2D are available on the tracer.
One strange thing I've noticed on the MALI system is that it can't play high-def videos at all. And my videos 1280x720 report on the debuger that they are using a SoftwareRenderer. Perhaps that's why the frames are not copied correctly to the OGL_IMAGE that will be used as a texture.
I guess I need some better understanding of what's going on under the hood, but I expected an error telling the system can't do it or it should simply work, even if the performance would be bad.
I'm attaching the source code for the testing app I've written.
  • Note: This was originally posted on 26th July 2013 at http://forums.arm.com
          have a similar problem on HP Slate 7 2801. But interestingly while an mp4 file stored on the device will only give a black texture, the exact same file when streamed (from my web site) displays perfectly.
    Is this just the slate or is it common to other mali devices?
    Now anyone know a webserver that can be used internal to an app to serve up video files?  Might be required if we are to support mali GPU!
    Regards
    Gerard.
    Regards
    Gerard.
