Site
Search
User
Site
Search
User
Groups
Arm Research
DesignStart
Education Hub
Graphics and Gaming
High Performance Computing
Innovation
Multimedia
Open Source Software and Platforms
Physical
Processors
Security
System
Software Tools
TrustZone for Armv8-M
中文社区
Blog
Announcements
Artificial Intelligence
Automotive
Healthcare
HPC
Infrastructure
Innovation
Internet of Things
Machine Learning
Mobile
Smart Homes
Wearables
Forums
All developer forums
IP Product forums
Tool & Software forums
Pelion IoT Platform
Support
Open a support case
Documentation
Downloads
Training
Arm Approved program
Arm Design Reviews
Community Help
More
Cancel
Developer Community
Tools and Software
Graphics and Gaming
Jump...
Cancel
Graphics and Gaming
Graphics and Gaming forum
Port from Mali-400 to Mali T604
Blog
Forum
Videos & Files
Help
Jump...
Cancel
New
Replies
Subscribers
133 subscribers
Views
Users
0 members are here
Mali Drivers
Mali-T604
Mali-GPU
Mali-400
Related
Offline
Jean-Georges Levieux
over 7 years ago
Note: This was originally posted on 17th December 2012 at
http://forums.arm.com
We are porting a game from a Mali 400 platform to a Mali T604 platform and we have some problems.
To be brief when we display 3D objects we only have a blackscreen (our 2D objects are visible). According to the vendor of the platform (which is also making the drivers) this is because we do not fill the alpha value of the color buffer (but this is obviously not the case on Mali 400). The driver team is investigating on their side because it could be something wrong in the driver (they also do the driver for the Mali 400) but I would like to get some thought from someone else on what can be so different on a MaliT604 and so what we have maybe missed...
Here are some things we have already tried without success:
- We use glError() function almost everywhere in our code and we do not have any error.
- Our shaders (vertex, fragment and linked prog) are ok and compil without error (online or offline with the arm tool).
- We have filled the alpha buffer at the start of the frame to 1.0 just to be sure.
- We have done some tests with the glColorMask() function.
- We have returned 1.0 for the alpha value in all fragment shaders.
Maybe the alpha thing is not really the problem and maybe we have something wrong elsewhere, but what... We need some ideas to help us!!!
Maybe the T604 do not accept something that the 400 accept more smoothly...
Thank you for your help!
Offline
Pete
over 7 years ago
there are a few differences between the Mali-400 family and the Mali-T604, but I'm struggling to think what could cause your result.
I wasn't quite clear on the results of your tests so far. Can I check the basics - can you get colour on the screen using something like this?
glClearColor(1.0, 0.0, 0.0, 1.0);
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT | GL_STENCIL_BUFFER_BIT);
That should be the most basic check which will eliminate issues with actual geometry and should show an opaque red screen.
If that's working, I'm also interested whether you're setting any precision qualifiers in your vertex shaders. I *think* the Mali-400 would have promoted mediump to 24-bit in its vertex processor, but since I believe the T604 supports full 32-bit quantities, mediump may only be 16-bit on that platform. In that case specifying highp on the T604 may yield a different result - although I'd have expected minor geometry glitches from the drop in accuracy rather than straight out missing geometry.
There is both simple SDK-type content and complex gaming content running on other T604 platforms so I suspect it must be a gotcha rather than anything serious!
HTH, Pete
Cancel
Up
0
Down
Cancel
Offline
over 7 years ago
Note: This was originally posted on 19th December 2012 at
First thank you very much for your quick answer.
We have found the issue, in fact the previous drivers given by the vendor was doing the clear (including the z buffer) itself when swapping the buffers, so we have just add a clear command for the Z-buffer and everything was ok... Quite simple finally...
BUT, your tips about the medium/high precision was very usefull as once we had something displayed we got many bugs with lighting computing in pixel shaders because of this. Thanks to your answer we fixed this very fast!
Thank you very much.
Regards,
Cancel
Up
0
Down
Cancel
By title
By date
By reply count
By view count
By most asked
By votes
By quality
Descending
Ascending
All recent questions
Unread questions
Questions you've participated in
Questions you've asked
Unanswered questions
Answered questions
Questions with suggested answers
Questions with no replies
Answered
Camera feed not showing on Mali-based chips
0
vulkan
Mali DDK for GPU (Midgard Architecture)
Mali GPU (Bifrost Architecture)
OpenGL ES
vulkan api
Mali DDK for GPU (Utgard Architecture)
6833
views
6
replies
Latest
3 months ago
by
Peter Harris
Not Answered
Is it possible read separated Alpha/RGB pixels for rendering?
0
9456
views
0
replies
Started
4 months ago
by
YoungJun
Answered
Query on FPK Occluder
+1
Mali GPU (Valhall Architecture)
arm streamline
9425
views
1
reply
Latest
4 months ago
by
Peter Harris
Not Answered
GLES enabling in BGFX for MAME
0
9574
views
1
reply
Latest
4 months ago
by
Yash Anand
Answered
Zero Copy Buffers using cl_arm_import_memory extension in OpenCL 1.2 - arm mali midgard GPUs.
+1
Midgard
Mali GPU (Midgard Architecture)
Mali OpenCL SDK
30096
views
8
replies
Latest
4 months ago
by
willhua
