glGenerateMipmap() very slow on Samsung Galaxy SII
Note: This was originally posted on 15th February 2012 at http://forums.arm.com
I'm currently doing some GPGPU on the Samsung Galaxy SII (Mali-400 MP). For that I need to generate a mipmap from a texture that has been rendered to via a FBO. Unfortunately glGenerateMipmap() appears to be very slow on the device. It takes about 90 milliseconds to generate a mipmap for a 512x512 RGBA8888 texture. Since I also tried the same code on other Android devices, where this function works much faster (about 2 milliseconds), this slowdown really puzzles me. Am I doing something wrong or missing something here? Can anyone provide example code for this case working on a MALI device?
Here are the relevant parts of my code:
glGenTextures(1, &texId);
glActiveTexture(GL_TEXTURE0);
glBindTexture(GL_TEXTURE_2D, texId);
// Allocate graphics memory.
glTexImage2D(GL_TEXTURE_2D, 0, format, cols, rows, 0, format, type, NULL);
// Allocate memory for mipmap.
glGenerateMipmap(GL_TEXTURE_2D);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR_MIPMAP_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
// Create off-screen framebuffer object and attach the texture to it.
glGenFramebuffers(1, &fboId);
glBindFramebuffer(GL_FRAMEBUFFER, fboId);
glFramebufferTexture2D(GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, GL_TEXTURE_2D, texId, 0);
// Now render to that texture
// Generate MIP map.
  • Note: This was originally posted on 13th August 2012 at http://forums.arm.com
    Has there ever been a resolution to this problem? I'm very interested to find out why the generation time for your object seems so large.
    Have you made any progress with your experimentation? Have you considered using the DS-5 profiler to get more insight into what's happening?
    Updates please!
    Updates please!
