I thought we could use a forum to share ideas on how to optimize graphics rendering on Mali-based devices. So, here's my first post on identifying bottlenecks in the rendering pipeline.We usually use frame rate, or frames per second (FPS), to measure graphics rendering performance. System FPS is the overall rendering performance when all system components (CPU, GPU, memory, display) are hooked up together. What system FPS fails to reveal, however, is how individual components in the rendering pipeline perform. Knowing each component's performance and locating bottlenecks is the first necessary step in optimizing graphics rendering on any Mali-based system.Graphics rendering on Mali is a frame-based pipelined process that involves several processing units. The process begins with the graphics application running on CPU making API calls to the Mali driver. The Mali driver then sets up data in system memory required by Mali GPU to render a frame. The GPU can't start rendering until the CPU has completely set up data for that frame.Within Mali GPU, the geometry processor (GP) consumes data previously set up by the CPU and passes them on to the pixel processor (PP). The PP can't start rendering until the GP completely sets up required data in memory for that frame.You get the picture. Data dependency between processing blocks means a bottleneck in any of the processing cores throttles the whole system FPS. In addition, processing cores need to access system memory so high memory latencies can potentially be a bottleneck as well.Using the Mali performance analysis tool (PAT), in conjunction with instrumented Mali drivers, one can usually spot a CPU-bound use-case easily. The measured system FPS would be significantly lower than GP or PP FPS (measured by PAT). See attached image.Has anyone found any interesting bottlenecks, or tricky ones to spot?
top - 14:18:01 up 1 min, 1 user, load average: 0.65, 0.29, 0.10Tasks: 24 total, 1 running, 23 sleeping, 0 stopped, 0 zombieCpu(s): 47.4%us, 25.4%sy, 0.0%ni, 2.6%id, 0.0%wa, 22.8%hi, 1.8%si, 0.0%stMem: 213540k total, 100892k used, 112648k free, 4228k buffersSwap: 0k total, 0k used, 0k free, 83568k cached PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 1097 root 20 0 32412 4108 2216 S 90.7 1.9 0:04.52 main 1098 root 20 0 2332 1080 892 R 6.2 0.5 0:00.53 top
top - 14:24:17 up 2 min, 1 user, load average: 1.26, 0.58, 0.23Tasks: 24 total, 3 running, 21 sleeping, 0 stopped, 0 zombieCpu(s): 21.8%us, 25.5%sy, 0.0%ni, 38.2%id, 0.0%wa, 13.6%hi, 0.9%si, 0.0%stMem: 213540k total, 100292k used, 113248k free, 5276k buffersSwap: 0k total, 0k used, 0k free, 80448k cached PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 1113 root 20 0 22460 2676 1592 R 49.3 1.3 0:20.84 main_pixmap_ump 1114 root 20 0 2332 1080 892 R 5.5 0.5 0:02.23 top
Tim, btw, Is it possible to use GLBenchmarking for Performance Optimization ?Ravindran
