Note: This was originally posted on 27th August 2013 at http://forums.arm.com
I am trying to get profiling information from a Mali-400 in configuration with an A13, using driver r1p1 release 1 for the Mali-400. Whenever I run GATOR, it checks for the callback called *_mali_osk_fbcontrol_set*, but it is nowhere to be found in the Mali-400 driver code, so it cannot retrieve profiling information from the GPU. Has anyone run into this problem? Is that callback available in other drivers, or do I need to get any missing modules ?
The error message I get while trying to capture gator information is "gator: mali online _mali_osk_fbcontrol_set symbol not found". While running the ds-5, it says the configuration is incompatible when trying to check any variables related to the Mali-400, but everything else (CPU, Mem) works flawlessly.
Any ideas?
I am trying to get profiling information from a Mali400 in configuration with an A13, using driver r1p1 release 1 for the Mali400. Whenever I run GATOR, it checks for the callback called *_mali_osk_fbcontrol_set*, but it is nowhere to be found in the Mali400 driver code, so it cannot retrieve profiling information from the GPU. Has anyone run into this problem? Is that callback available in other drivers, or do I need to get any missing modules ? The error message I get while trying to capture gator information is "gator: mali online _mali_osk_fbcontrol_set symbol not found". While running the ds-5, it says the configuration is incompatible when trying to check any variables related to the Mali400, but everything else (CPU, Mem) works flawlessly. Any ideas?
Hi Iscandolo,
1) Could you please confirm that you have built GATOR using following settings:
GATOR_WITH_MALI_SUPPORT=MALI_400 KCFLAGS=\"-I/path/to/ddk/source -DGATOR_MALI_INTERFACE_STYLE=3 -DGATOR_TEST_ENABLED -DxxDEBUG\" make -j8 -C /path/to/linux/kernel M=`pwd` ARCH=arm CROSS_COMPILE=arm-eabi- modules"
2) Are you getting warnings about any other missing symbols or just the one about _mali_osk_fb_control_set ?
Is this still an issue for you? Do you need further assistance with this?
Kind Regards
Sorry for the delay in answering, I've been tied up in other projects.
I compiled gator following kubacki's instructions and using driver r3p2-01rel1 and now it works!
Thanks for the help guys!
