Hi Memeka,Apologies for the delayed response.Could you run strings on mali.ko to find the API level, failing that, the revision number from libmali.so? The issue with reduced performance could be caused by attempting to use kernel driver modules known to be incompatible with this revision of the Linux kernel.Kind Regards,Rich
