Site
Search
User
Site
Search
User
Groups
Arm Research
DesignStart
Education Hub
Graphics and Gaming
High Performance Computing
Innovation
Multimedia
Open Source Software and Platforms
Physical
Processors
Security
System
Software Tools
TrustZone for Armv8-M
中文社区
Blog
Announcements
Artificial Intelligence
Automotive
Healthcare
HPC
Infrastructure
Innovation
Internet of Things
Machine Learning
Mobile
Smart Homes
Wearables
Forums
All developer forums
IP Product forums
Tool & Software forums
Pelion IoT Platform
Support
Open a support case
Documentation
Downloads
Training
Arm Approved program
Arm Design Reviews
Community Help
More
Cancel
Developer Community
Tools and Software
Graphics and Gaming
Jump...
Cancel
Graphics and Gaming
Graphics and Gaming forum
DX910-SW-99002-r3p1-01rel0 linux kernel 3.0.39
Blog
Forum
Videos & Files
Help
Jump...
Cancel
New
Replies
Subscribers
133 subscribers
Views
Users
0 members are here
Mali-GPU
Mali-400
Related
Offline
Domenic Troilo
over 7 years ago
Note: This was originally posted on 30th August 2012 at
http://forums.arm.com
I thought I would play with the latest software provided by Mali found
here
I have a current kernel built at 3.0.39 and have been able to compile both the latest source code above ump.ko and mali.ko with a little extra effort.
When I compare the kernel mali sources against the malideveloper sources there is a slight configuration difference that being the "platform" information which is used to describe the hardware configuration. This is the arch/config.h from the kernel sources (this is a link to the config.h in directory arch-ca8-virtex820-m400-1):
/* * This confidential and proprietary software may be used only as * authorised by a licensing agreement from ARM Limited * (C) COPYRIGHT 2008-2010 ARM Limited * ALL RIGHTS RESERVED * The entire notice above must be reproduced on all authorised * copies and copies may only be made to the extent permitted * by a licensing agreement from ARM Limited. */
ifndef ARCH_CONFIG_H
define ARCH_CONFIG_H
/* Configuration for the EB platform with ZBT memory enabled */
static _mali_osk_resource_t arch_configuration [] = { { .type = PMU, .description = "Mali-400 PMU", .base = 0x01C42000, .irq = 73, .mmu_id = 0 }, { .type = MALI400GP, .description = "Mali-400 GP", .base = 0x01C40000, .irq = 69, .mmu_id = 1 }, { .type = MALI400PP, .base = 0x01C48000, .irq = 71, .description = "Mali-400 PP", .mmu_id = 2 }, { .type = MMU, .base = 0x01C43000, .irq = 70, .description = "Mali-400 MMU for GP", .mmu_id = 1 }, { .type = MMU, .base = 0x01C44000, .irq = 72, .description = "Mali-400 MMU for PP", .mmu_id = 2 }, { .type = MEMORY, .description = "Mali Sdram", .alloc_order = 0, /* highest preference for this memory / .base = 0x5C000000, .size = 64 * 1024 * 1024, /*64M/ .flags = _MALI_CPU_WRITEABLE | _MALI_CPU_READABLE | _MALI_MMU_READABLE | _MALI_MMU_WRITEABLE }, { .type = MEM_VALIDATION, .description = "Framebuffer", .base = 0x5A000000, .size = 32 * 1024 * 1024, /32M/ .flags = _MALI_CPU_WRITEABLE | _MALI_CPU_READABLE | _MALI_MMU_READABLE | _MALI_MMU_WRITEABLE }, { .type = OS_MEMORY, .description = "OS Memory", .alloc_order = 1, /* Lowest preference for this memory / .size = 192 * 1024 * 1024, / 64 MB */ .flags = _MALI_CPU_WRITEABLE | _MALI_CPU_READABLE | _MALI_MMU_READABLE | _MALI_MMU_WRITEABLE }, { .type = MALI400L2, .base = 0x01C41000, .description = "Mali-400 L2 cache" }, };
endif /* ARCH_CONFIG_H */
When you build the new code the arch-ca8-virtex820-m400-1 platform does not exist (not provided by malideveloper). I copied the arch-ca8-virtex820-m400-1 into the source directory and specified this as for the configuration and the module compiles. When I try to load the module I get this:
[ 9.400000] Mali: [ 9.400000] Mali: Inserting Mali v17 device driver. [ 9.410000] Mali: Compiled: Aug 29 2012, time: 14:30:44. [ 9.420000] Mali: Driver revision: r3p1-01rel0 [ 9.430000] Mali: Memory system initializing [ 9.440000] Mali: Memory Validator 'Framebuffer' installed for Mali physica l address base=0x5A000000, size=0x02000000 [ 9.460000] Mali: Mali OS memory allocator created with max allocation size of 0xC000000 bytes, cpu_usage_adjust 0x00000000 [ 9.480000] Mali: Mali PMU: Creating Mali PMU core [ 9.500000] Mali: Mali PP: Creating Mali PP core: Mali-400 PP [ 9.510000] Mali: Mali PP: Base address of PP core: 0x1c48000 [ 9.520000] Mali: Mali PP: Failed to reset core Mali-400 PP, Status: 0x0000 0000 [ 9.530000] Mali: ERR: /usr/src/tmp/kernel/DX910-SW-99002-r3p1-01rel0/driver/s rc/devicedrv/mali/common/mali_kernel_core.c [ 9.550000] mali_parse_product_info() 190 [ 9.570000] Mali: Memory system terminating [ 2025.500000] Mali:
So I have to ask, where did the kernel arch-ca8-virtex820-m400-1 product information come from? And why is this not valid anymore with the new code.... of course this is not likely a good place to post this question, but then I need to start somewhere....
Domenic
Offline
Karthik Hariharakrishnan
over 7 years ago
Note: This was originally posted on 5th September 2012 at
Hi Domenic,
You mention that the sources from malideveloper.com do not contain the platform information for arch-ca8-virtex820-m400-1. Could I ask you which sources you are comparing against? We only publish the driver sources in malideveloper.com.
Also, could you give us some more information on the Mali platform you are using? It might just be that you will need to configure the memory and interrupts for your platform. The hardware configuration given as part of arch-ca8-virtex820-m400-1 might not work for you.
Cheers
Karthik
Cancel
Up
0
Down
Cancel
Offline
Domenic Troilo
over 7 years ago
I am using the allwinner kernel sources found here: git://github.com/amery/linux-allwinner.git and I have been able to build the drivers!!! I had to copy the /usr/src/linux-allwinner/drivers/gpu/mali/mali/arch-ca8-virtex820-m400-1 and /usr/src/linux-allwinner/drivers/gpu/mali/mali/platform/mali400-pmu directories to the devicedrv/mali directory and build with this command line: KDIR=/usr/src/linux-allwinner USING_UMP=1 TARGET_PLATFORM=mali400-pmu CONFIG=ca8-virtex820-m400-1 make
Looks good!
Domenic
Cancel
Up
0
Down
Cancel
By title
By date
By reply count
By view count
By most asked
By votes
By quality
Descending
Ascending
All recent questions
Unread questions
Questions you've participated in
Questions you've asked
Unanswered questions
Answered questions
Questions with suggested answers
Questions with no replies
Not Answered
mali-checker showing as no opengl es version support available.
0
4113
views
0
replies
Started
2 months ago
by
tattimano
Answered
Zero GPU activity during "long" periods of time
+1
Mali GPU (Bifrost Architecture)
Streamline Performance Analyzer
5165
views
5
replies
Latest
2 months ago
by
JPJ
Answered
Help interpreting L/S and Texture memory usage
0
5582
views
4
replies
Latest
2 months ago
by
JPJ
Not Answered
Display problem in GTK/Webkit with RK3288 Mali-T764
0
4710
views
1
reply
Latest
2 months ago
by
IronKang
Answered
Texture Cache on Mali-G76
+1
4996
views
1
reply
Latest
2 months ago
by
Kévin Petit
