MALI-400 Driver Support Issue
Note: This was originally posted on 25th September 2012 at http://forums.arm.com
I am working on Galaxy S3, Exynos quad-core, [font=sans-serif]1.4 GHz quad-core [/font]Cortex-A9 with MALI-400 MP.
The device is using Android Jelly Bean. Linux/arm version is Linux/arm 3.0.31 Kernel.
While using profiling (streamline) in DS-5, GPU snippets are not showing.
"Chart configuration is incompatible with this configuration is showing when GPU counters are selected.
Before that, I built gator.ko and gatord and copied them into same directory in target.
Using DS-5, I can get CPU performance counters but not GPU counters.
I even generated gator.ko with "GATOR_WITH_MALI_SUPPORT=MALI-400".
Can anyone kindly guide me about where are we missing something.
[size=2]Thanks a lot.[/size]
Yasir.
  • Note: This was originally posted on 30th December 2012 at http://forums.arm.com
    Hi Yasir, Medge,
    Any updates on the issue. I am also facing exactly the same problem, except that my issue is on Nexus 10(MALI-T604).
    If you could share the solution/status for this issue, it could well solve my issue as well.
    thanks and regards,
    Karthick
    Hi,all
    I also got the same problem on rk3066 platform.Waiting for the solution.
    Thanks a lot
    Simon
    Hi Yasir, Medge,
    thanks and regards,
    Karthick
    Hi,all
    Thanks a lot
    Simon
