Debugging Mali driver in 3.4 kernel in Origen
Note: This was originally posted on 26th April 2012 at http://forums.arm.com
Hello
I am trying to make ICS Android (Mali) work in Origen with 3.4 kernel
Now  as using Mali driver, gralloc_ump r2p4-02rel in 3.4 kernel with the following Android branch.
repo init -u git://android.git.linaro.org/platform/manifest.git -b linaro_android_4.0.4 -m tracking-origen.xml
I have the following errors:
[   15.225000] MALI PHYSICAL RANGE VALIDATION ERROR!
[   15.235000] We failed to validate a Mali-Physical range that the user-side wished to map in
[   15.245000] It is likely that the user-side wished to do Direct Rendering, but a suitable
[   15.250000] address range validation mechanism has not been correctly setup
[   15.260000] The range supplied was: phys_base=0x6D900000, size=0x004B0000
[   15.270000] Please refer to the ARM Mali Software Integration Guide for more information.
[   15.275000] *******************************************************************************
In my opinion, it seems that user space library call ioctl command with in-proper argument.
    ioctl command (MALI_IOC_MEM_MAP_EXT)  with the wrong params: phys_base=0x6D900000, size=0x004B0000
In addition, currently I didn't  add UMP remap call  in  Framebuffer drivers.  Is it possible reason ?
Sangwook
