Mali gpu texture compression for Linux
Note: This was originally posted on 14th January 2013 at http://forums.arm.com
The complete output is: WARNING: Error compressing ("/home/../carpetHalved_atlas.png"): "Error: Could not convert input image /home/../carpetHalved_atlas.png to .ppm"  The png is the same one as used in Mali SDK for android. It does not work with any combination of settings, or other png files.
As I don't see any other useful error info, I don't really know which is the reason for it. On a windows system it seems to work. It fails on an Ubuntu 12.04.
Could you help me with it?
Thank you,
Bogdan
  • Note: This was originally posted on 14th January 2013 at http://forums.arm.com
    I was trying both command line and GUI, with same result. Also, now I tried changing path of convert to Image Magick utility in my system (/usr/bin/convert), with same result. Can I break the command in several subcommands? Which should be the parameters to convert?
    Regards,
    Bogdan
    Regards,
    Bogdan
