Can a Mali-G71 use a SSBO in a vertex shader ?
I've been able to set up a SSBO (storage shader buffer object) and use it in both a compute and fragment shaders.
Moreover, I would like to use it directly in a vertex shader :
layout(std140, binding = 3) buffer destBuffer
    mediump float data[];
However, I get an error message :
The number of vertex shader storage blocks (1) is greater than the maximum number allowed (0)
Is it possible to fix this ?
If not, is there a way to prodive data modified in a compute shader to a vertex shader.
Thank you.
  • Is it possible to fix this ?
    No; the current limit supported by Mali is zero so the error message is correct in this case.
    As long as the vertex shader usage is read-only, and the buffer fits inside the UBO size limits, can you just bind it as a uniform buffer for the vertex shader draw call?
    Cheers,
    Pete
    Cheers,
    Pete
