Mali Graphics Debugger unable to compile shaders
I'm having issues analyzing shader cycle count of an OpenGLES 2.0 application using the linux version of Mali Graphics Debugger 5.1.0.8a0102de (the target is running a Mali400-MP2 GPU on linux). Cycle analysis is working fine under the same MGD version on windows however!
The symptoms are as follows:
For most shaders, but not all, the fields for cycles / A / L/S and T fields are all set to "N/A", and hovering above these fields prints a tooltip with the message "Unable to run the mali offline compiler". On the console, I'm seeing a few warnings of the form:
[WARNING]:  Error compiling shader in GlShaderCompiler: For input string: "2,6"
Is there a way to better understand what's tripping up the shader compiler?
The standalone offline compiler doesn't have any issues compiling the respective shaders and reporting the cycle counts, and the windows version of MGD works as well, so this seems to be a fairly low-level string processing/locale issue. Maybe just a newline issue or somesuch? Any hints appreciated!
