Mali Offline Compiler Result analysis
Hello everyone,
When I use Mali Offline Compiler to get shader's performance analysis.
But I don't know,Why are there two rendering targets?,render target 0,render target 1.
What do they mean?
  • Hi Shengteng,
    The Mali compiler can generate multiple variants of a shader program, giving the run-time driver a choice of multiple shaders with different performance characteristics. In many cases the generic shader which is always safe to use will be slightly slower than a specialized shader, but the specialized shader can only be used if some specific run-time conditions are met.
    I've raised a bug report with the engineering team to improve the naming here, as I agree that it is confusing.
    Kind regards,
    Pete
  • Hi Shengteng,
    Kind regards,
    Pete
