Arm mobile studio not work in OSX (or all ?)
Guys, hello, but your studio does not start (I have OSX) and after installation, (I downloaded and unpacked) I registered the paths in the file as it was mentioned in the readme. After that, I tried to start (by writing sudo spctl --master-disable first) to the streamline and the Graphics analyzer - nothing started: the streamliner got lost and disappeared, and the analyzer showed the following error
After that, I read how to correct this error and put the following line into info.plist:
<key>Eclipse</key>
<array>
<!-- to use a specific Java version (instead of the platform's default) uncomment one of the following options,
or add a VM found via $/usr/libexec/java_home -V
<string>-vm</string><string>/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Commands/java</string>
<string>-vm</string><string>/Library/Java/JavaVirtualMachines/1.8.0.jdk/Contents/Home/bin/java</string>
<string>-keyring</string>
I rewrote this way:
<key>Eclipse</key>
<array>
<string>-vm</string><string>/Library/Java/JavaVirtualMachines/jdk-10.jdk/Contents/Home/bin</string>
, after that the program did not work, but showed a different error, the program recorded it in the log, which I attached to this post. But nothing has earned. Here is a problem
ErrorLog.log
!SESSION 2019-04-20 15:23:18.257 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_60
java.vendor=Oracle Corporation
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments:  -keyring /Users/sergeiloskutnikov/.eclipse_keyring
Command-line arguments:  -os macosx -ws cocoa -arch x86_64 -data @user.home/.aga_workspace_5.2.0 -keyring /Users/sergeiloskutnikov/.eclipse_keyring
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-04-20 15:23:22.428
!MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/63B0A678-8588-401B-A6B3-C364AA629710/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar.
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-04-20 15:23:22.466
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-04-20 15:23:22.497
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-04-20 15:23:22.523
!SESSION 2019-05-26 10:55:00.500 -----------------------------------------------
java.version=10
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_RU
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 10:55:05.511
!MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/CA444C30-D5EA-4457-B5E8-6DD8F41236E2/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar.
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 10:55:05.571
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 10:55:05.604
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 10:55:05.634
!ENTRY org.eclipse.osgi 4 0 2019-05-26 10:55:06.860
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:632)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
	at com.arm.mgd.ui.Application.start(Application.java:112)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:564)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
	... 22 more
Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
	at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499)
	... 24 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-26 10:55:06.870
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.lang.NoClassDefFoundError: javax/annotation/PreDestroy
	at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426)
	at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154)
	at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176)
	at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106)
	at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156)
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
	at org.eclipse.osgi.container.Module.doStop(Module.java:634)
	at org.eclipse.osgi.container.Module.stop(Module.java:498)
	at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
	at java.base/java.lang.Thread.run(Thread.java:844)
Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927
	... 21 more
!SESSION 2019-05-26 11:00:37.083 -----------------------------------------------
java.version=10
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:00:40.651
!MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D92FA5A1-9F04-41BC-A58F-D34FC610A58B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar.
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:00:40.695
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:00:40.735
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:00:40.762
!ENTRY org.eclipse.osgi 4 0 2019-05-26 11:00:41.766
!STACK 1
	... 22 more
	... 24 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-26 11:00:41.776
!STACK 0
	... 21 more
!SESSION 2019-05-26 11:06:58.701 -----------------------------------------------
java.version=10
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:07:02.216
!MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/D6390C76-0C01-4A0E-9556-003A9CF51F84/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar.
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:07:02.271
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:07:02.305
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 11:07:02.338
!ENTRY org.eclipse.osgi 4 0 2019-05-26 11:07:03.357
!STACK 1
	... 22 more
	... 24 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-26 11:07:03.366
!STACK 0
	... 21 more
!SESSION 2019-05-26 12:06:06.122 -----------------------------------------------
java.version=10
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 12:06:11.253
!MESSAGE Unable to acquire PluginConverter service during generation for: /private/var/folders/f1/f5b0cbrn3kz08pw4sh_l64h40000gn/T/AppTranslocation/1C516BFA-22F7-45AC-B18C-70CDFAE9524B/d/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar.
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 12:06:11.297
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 12:06:11.332
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-26 12:06:11.361
!ENTRY org.eclipse.osgi 4 0 2019-05-26 12:06:12.493
!STACK 1
	... 22 more
	... 24 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-26 12:06:12.508
!STACK 0
	... 21 more
  • Hi Sergey,
    Thanks for the bug report; I will pass on to the engineering team to see if they have any ideas. What specific version of macOS are you running?
    Cheers,
    Pete
  • Hi Sergey,
    Thanks for the information; we've had this working on at least one Mojave-based machine internally so this is a new issue we've not seen before.
    We have a new release due out soon (this week hopefully), which will switch the macOS installation to use a signed .dmg disk image, which should avoid issues caused by the application translocation randomizing paths. At this point it's probably sensible to wait for that, given it's due out in the very near future.
    In the interim, our engineering team noted that you are using a JDK10 install for the custom JDK you are providing, which is likely to be to new (we ship with a JDK8 build).
    *EDIT* On a clean OS X 10.9.5 machine (no spctl has been run there), the following works for us:
    $ which java
    /usr/bin/java
    $ /usr/bin/java -version
    <... 1.8.0_66-b17 ... in my case>
    $ cd /Users/<user>/Downloads/mobilestudio-macosx/graphics_analyzer/
    $ graphics_analyzer/gui/Graphics\ Analyzer.app/Contents/MacOS/aga -vm /usr/bin
    Cheers,
    Pete
  • I did what you wrote above - again it did not start, and here is a log. In any case, I will wait for the update =))
    adaLog.log
    java.version=10
    !STACK 1
    	... 22 more
    	... 24 more
    !STACK 0
    	... 21 more
    java.version=10
    !STACK 1
    	... 22 more
    	... 24 more
    !STACK 0
    	... 21 more
    java.version=10
    !STACK 1
    	... 22 more
    	... 24 more
    !STACK 0
    	... 21 more
    java.version=10
    !STACK 1
    	... 22 more
    	... 24 more
    !STACK 0
    	... 21 more
    !SESSION 2019-05-28 15:57:03.633 -----------------------------------------------
    java.version=10
    !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-28 15:57:08.743
    !MESSAGE Unable to acquire PluginConverter service during generation for: /Users/sergeiloskutnikov/Downloads/DSHVE-BN-00005-r19p0-23rel0/mobilestudio-macosx/graphics_analyzer/gui/Graphics Analyzer.app/Contents/Eclipse/plugins/MIT.jar.
    !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-28 15:57:08.817
    !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-28 15:57:08.874
    !ENTRY org.eclipse.equinox.p2.publisher.eclipse 4 0 2019-05-28 15:57:08.917
    !ENTRY org.eclipse.osgi 4 0 2019-05-28 15:57:10.250
    !STACK 1
    	... 22 more
    	... 24 more
    !ENTRY org.eclipse.e4.ui.workbench 4 0 2019-05-28 15:57:10.261
    !STACK 0
    	... 21 more
Reply Children
