I have few Vulkan games run well on numbers of Android devices. However, when I test them on HUAWEI P30 (not P30 Pro) with Mali-G76 MP10 GPU and Android 9.0, function vkCreateDevice() returns error VK_ERROR_FEATURE_NOT_PRESENT (VkResult:-8).
My app should have successfully loaded Vulkan dynamic lib since vkInstance has been created before creating vkDevice.
So what is the reason that vkCreateDevice() return VK_ERROR_FEATURE_NOT_PRESENT? Here is my code snippet:
// Create Logical Device, ensure that this device is connecte to graphics queue// Step 1 - Retrive the queue family that supports graphics pipelineuint32_t graphicQueueFamilyIndex;int i = 0;for (const auto& family : _queueFamilyProps){ // Check if the family has queues and that are Graphical and not Computational queues. if (family.queueCount > 0 && family.queueFlags & VK_QUEUE_GRAPHICS_BIT) { graphicQueueFamilyIndex = i; //Found the family, record its index break; } i++;}// Step 2 - Get physical device featuresvkGetPhysicalDeviceFeatures(vkPhyDevice, &deviceFeatures); VkPhysicalDeviceFeatures enabledFeatures = {VK_FALSE};enabledFeatures.samplerAnisotropy = deviceFeatures.samplerAnisotropy;enabledFeatures.shaderSampledImageArrayDynamicIndexing = deviceFeatures.shaderSampledImageArrayDynamicIndexing;enabledFeatures.depthClamp = VK_TRUE;enabledFeatures.sampleRateShading = VK_TRUE;#if defined (NATIVE_LINEWIDTH_SUPPORT) enabledFeatures.wideLines = VK_TRUE; //MoltenVK (via Metal API) does not support line width#endif// Step 3 - Create the logical devicefloat queuePriorities[1] = { 0.0f };VkDeviceQueueCreateInfo queueCreateInfo { VK_STRUCTURE_TYPE_DEVICE_QUEUE_CREATE_INFO, //sType nullptr, //pNext 0, //flags graphicQueueFamilyIndex, //queueFamilyIndex 1, //queueCount queuePriorities //pQueuePriorities};std::vector<const char *> extensionNames { VK_KHR_SWAPCHAIN_EXTENSION_NAME };VkDeviceCreateInfo deviceInfo{ VK_STRUCTURE_TYPE_DEVICE_CREATE_INFO, //sType nullptr, //pNext 0, //flags 1, //queueCreateInfoCount &queueCreateInfo, //pQueueCreateInfos 0, //enabledLayerCount nullptr, //ppEnabledLayerNames (uint32_t)extensionNames.size(), //enabledExtensionCount extensionNames.data(), //ppEnabledExtensionNames &enabledFeatures //pEnabledFeatures };VK_ASSERT(vkCreateDevice(vkPhyDevice, &deviceInfo, nullptr, &vkDevice));
It turns out that "enabledFeatures.depthClamp = VK_TRUE;" should be removed from the enabled feature list. After that it is working.
I should have tried to remove some device features before I post this question, is now solved.
Glad you fixed the issue.
King regards,
Ben
Hi Ben,
I also found that another Vulkan feature "fillModeNonSolid" is not support by Mali Vulkan Driver (I have tested on Mali-T880 and Mali-G76).
This feature is important when need to render 3D object in wireframe mode. Interestingly, when I switch the graphics back-end of my app back to OpenGL ES, the wireframe rendering works well by "glPolygonMode(GL_FRONT_AND_BACK, GL_LINE);", which means the GPU is actually capable of doing wireframe rendering.
So why Mali vulkan driver disable this feature even if the GPU is capable of that? Wondering if this feature can be back in the future Vulkan driver.
Thanks.
Thanks for the feedback - I'll raise with the GPU product management team.
Cheers, Pete
