Load an image in QVGA format into a ARM Compute Library ICTensor.
Hi.
I am trying to load an image in QVGA format into a ARM Compute Library ICtensor. This is my current code:
CLTensor in0;
in0.allocator()->init(TensorInfo(TensorShape(320U, 240U), 1, DataType::U8));
But in Compute Library "Image" are dined with a Format and dimensions expressed as [width, height, batch].
And a Tensor is defined by a DataType plus a number of channels (Always expected to be 1 for now) and their dimensions are expressed as [width, height, feature_maps, batch].
So, what is suggested to use for the parameters "batch" and feature_maps?
Thanks.
  • Hi ,
    and thanks for using Arm Compute Library. In order to use the RGB or RGBA format, you should initialize your tensor in the following manner:
    CLTensor in0;
    in0.allocator()->init(TensorInfo(320U, 240U, Format::RGB));
    in this manner you create a 2D tensor with 3 channels (RGB) interleaved. However, just few operations are supported with this data layout so I suggest to convert your input QVGA in a planar data layout (each plane stores the values of each channel). In this manner you can use most of the functions available for Compute Library.
    You might have something like:
    CLTensor in0;
     // Convert to data layout to planar using CLChannelExtract and CLChannelCombine
    The output of CLChannelCombine should be:
    CLTensor out;
    out.allocator()->init(TensorInfo(TensorShape(320U, 240U, 3U), 1, DataType::U8));
    Hope this can help.
    Do not hesitate to write on github (github.com/.../issues) if you need any further information.
    Gian Marco
