Hi
Such a problem, more precisely a few. I want to debug my own android game. I have two devices (armeadi-v7a, samsung tab s2 8.0 (Mali-T760, android 21) and Honor 7X(arm64-v8a, Mali-T830, android 26) and I work with Mali Graphics Debugger (version 4.9.3 - host system OSX High Sierra 10.13.6). The problem is that on no one device working with debugging. Samsung : ( I launch as unrooted devices ) after I have done all the steps from User guide Mali debugger - When you run the application, you get the following error:
E/libMGD: Tried to add symbol with same name: glEGLImageTargetTexture2DOES Caught exception in initialiseRelocator: Tried to add symbol with same name: glEGLImageTargetTexture2DOES
And on this place stops loading.
Honor : Everything is fixed, But, after the connection - it is there and on the idea should show on the screen - nothing happens. That is, I see a blank application screen Mali Graphics Debugger.
That is, it does not work on any device. What is surprising. And yet, a year ago, everything worked for me owns samsung.
Hi Sergey, I've raised this with the MGD team, so hopefully we can shed some light on this.
Cheers, Pete
Many thanks, I want you to know, for my part I am ready to render any possible help
I also encountered the same issue on Samsung SM-T280. Logs:
08/03 12:13:44: Launching XXXXX$ adb install-multiple -r -t -p XXXXXSplit APKs installed$ adb shell am start -n "XXXXX" -a android.intent.action.MAIN -c android.intent.category.LAUNCHERClient not ready yet..Connected to process 19040 on device sm_t280-31001b96218f3300Capturing and displaying logcat messages from application. This behavior can be disabled in the "Logcat output" section of the "Debugger" settings page.I/MultiDex: VM with version 2.1.0 has multidex support Installing application VM has multidex support, MultiDex support library is disabled.I/InstantRun: starting instant run server: is main processW/linker: libMGD.so: unused DT entry: type 0x6ffffffe arg 0x1d59c libMGD.so: unused DT entry: type 0x6fffffff arg 0x3I/libMGD: Initialising interceptor. Skipping line a2587000-a2ce6000 r-xp 00000000 b3:1b 66215 /XXXXX/lib/arm/libMGD.so Skipping line a2ce7000-a2d02000 r--p 0075f000 b3:1b 66215 /XXXXX/lib/arm/libMGD.so Skipping line a2d02000-a2d03000 rw-p 0077a000 b3:1b 66215 /XXXXX/lib/arm/libMGD.so Skipping line aa131000-aa241000 r-xp 00000000 b3:19 1303 /system/lib/egl/libGLES_mali.so Skipping line aa242000-aa245000 r--p 00110000 b3:19 1303 /system/lib/egl/libGLES_mali.so Skipping line aa245000-aa249000 rw-p 00113000 b3:19 1303 /system/lib/egl/libGLES_mali.soI/libMGD: Skipping line b6cc0000-b6d1d000 r-xp 00000000 b3:19 1339 /system/lib/libEGL.so Skipping line b6d1d000-b6d1f000 r--p 0005c000 b3:19 1339 /system/lib/libEGL.so Skipping line b6d1f000-b6d28000 rw-p 0005e000 b3:19 1339 /system/lib/libEGL.soI/libMGD: Parsing /data/dalvik-cache/arm/data@app@XXXXX@base.apk@classes.dexV/libMGD: Couldn't locate DT_JMPREL relocations tableI/libMGD: Could not parse /data/dalvik-cache/arm/data@app@XXXXX@base.apk@classes.dex Parsing /system/bin/app_process32V/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 1 symbol relocations in /system/bin/app_process32 Parsing /system/bin/linkerV/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 0 symbol relocations in /system/bin/linker Parsing /system/framework/arm/boot.oatV/libMGD: Couldn't locate DT_JMPREL relocations tableI/libMGD: Could not parse /system/framework/arm/boot.oat Parsing /system/lib/libAstcEnc.soV/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 0 symbol relocations in /system/lib/libAstcEnc.so Parsing /system/lib/libETC1.soV/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 0 symbol relocations in /system/lib/libETC1.so Parsing /system/lib/libGLES_trace.soV/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 0 symbol relocations in /system/lib/libGLES_trace.so Parsing /system/lib/libGLESv1_CM.soV/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 7 symbol relocations in /system/lib/libGLESv1_CM.so Parsing /system/lib/libGLESv2.soV/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 0 symbol relocations in /system/lib/libGLESv2.so Parsing /system/lib/libLLVM.soV/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 2 symbol relocations in /system/lib/libLLVM.so Parsing /system/lib/libRS.soV/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 2 symbol relocations in /system/lib/libRS.so Parsing /system/lib/libRScpp.soV/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 2 symbol relocations in /system/lib/libRScpp.so Parsing /system/lib/libSEF.soV/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 0 symbol relocations in /system/lib/libSEF.so Parsing /system/lib/libSEF4MP4.soV/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 0 symbol relocations in /system/lib/libSEF4MP4.so Parsing /system/lib/libandroid.soV/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 0 symbol relocations in /system/lib/libandroid.so Parsing /system/lib/libandroid_runtime.soV/libMGD: Couldn't locate DT_RELA relocations tableI/libMGD: Found 558 symbol relocations in /system/lib/libandroid_runtime.soE/libMGD: Tried to add symbol with same name: glEGLImageTargetTexture2DOESE/libMGD: Caught exception in initialiseRelocator: Tried to add symbol with same name: glEGLImageTargetTexture2DOESApplication terminated.
Hello Serjey, sdjt,thank you for your bug report!> E/libMGD: Tried to add symbol with same name: glEGLImageTargetTexture2DOES> Caught exception in initialiseRelocator: Tried to add symbol with same name: glEGLImageTargetTexture2DOES>I was not able to reproduce it with the device at hand, but I will look for a Samsung Galaxy Tab as soon as possible.Meanwhile I looked at our source code and I may have spotted a regression introduced since 4.9.2.If my hypothesis is correct, Mali Graphics Debugger 4.9.0 (https://developer.arm.com/products/software-development-tools/graphics-development-tools/mali-graphics-debugger/downloads) will work.I will try my best to find and fix the bug by the upcoming patch release and I will keep you posted.> Honor : Everything is fixed, But, after the connection - it is there and on the idea should show on the screen - nothing happens. > That is, I see a blank application screen Mali Graphics Debugger. >Could you share/attach the logcat output?It may shed some light on what is going on there.Alberto
Hi Alberto
Thank you for your help!
I installed the version 4.9.0 - And at me all has earned on the device samsung galaxy tab s2 8.0 ! (Its fine work )
Honor7X - Also does not launch the application in Mali graphics Debugger (MGD version 4.9.0) Attach Logs:
logcatHonor7X.txt
