Hi
Such a problem, more precisely a few. I want to debug my own android game. I have two devices (armeadi-v7a, samsung tab s2 8.0 (Mali-T760, android 21) and Honor 7X(arm64-v8a, Mali-T830, android 26) and I work with Mali Graphics Debugger (version 4.9.3 - host system OSX High Sierra 10.13.6). The problem is that on no one device working with debugging. Samsung : ( I launch as unrooted devices ) after I have done all the steps from User guide Mali debugger - When you run the application, you get the following error:
E/libMGD: Tried to add symbol with same name: glEGLImageTargetTexture2DOES Caught exception in initialiseRelocator: Tried to add symbol with same name: glEGLImageTargetTexture2DOES
And on this place stops loading.
Honor : Everything is fixed, But, after the connection - it is there and on the idea should show on the screen - nothing happens. That is, I see a blank application screen Mali Graphics Debugger.
That is, it does not work on any device. What is surprising. And yet, a year ago, everything worked for me owns samsung.
Hello Serjey, sdjt,thank you for your bug report!> E/libMGD: Tried to add symbol with same name: glEGLImageTargetTexture2DOES> Caught exception in initialiseRelocator: Tried to add symbol with same name: glEGLImageTargetTexture2DOES>I was not able to reproduce it with the device at hand, but I will look for a Samsung Galaxy Tab as soon as possible.Meanwhile I looked at our source code and I may have spotted a regression introduced since 4.9.2.If my hypothesis is correct, Mali Graphics Debugger 4.9.0 (https://developer.arm.com/products/software-development-tools/graphics-development-tools/mali-graphics-debugger/downloads) will work.I will try my best to find and fix the bug by the upcoming patch release and I will keep you posted.> Honor : Everything is fixed, But, after the connection - it is there and on the idea should show on the screen - nothing happens. > That is, I see a blank application screen Mali Graphics Debugger. >Could you share/attach the logcat output?It may shed some light on what is going on there.Alberto
Hi Alberto
Thank you for your help!
I installed the version 4.9.0 - And at me all has earned on the device samsung galaxy tab s2 8.0 ! (Its fine work )
Honor7X - Also does not launch the application in Mali graphics Debugger (MGD version 4.9.0) Attach Logs:
logcatHonor7X.txt
