there counters were not added because your target does not support them
Hello.
As for the Streamline tool, I haven't solved the problem in two days.
Please respond quickly.
The situation is as follows :
Version : Arm Streamline Performance Analyzer Version 6.5.1, Build 20180103_121655
Mobile Devices : Galaxy S7, android 6.0.1, This is a routed phone.
The error path is : "streamline > Counter Configuration > add counters from to template > [Built-in] Mali Midgard"
The following error occurred : "there counters were not added because your target does not support them"
                                                 GPUVertexTilingComputeActivity
                                                 GPUFragmentActivity
Thank you
  • These counters require that the Mali kernel driver shipped with the phone has been built to support virtual counters which export these events to the Gator driver. If the device manufacturer has not configured their kernel driver to support these counters then they will not be supported on the device; just deselect them from the counter selection.
    HTH,
    Pete
    HTH,
    Pete
