sadly ARM software avoids the kernel on my device to be patched. I'm not ablet in anyway to compile a working mali.ko kernel module to get the binaries libMali.so and libUmp.so connected to them. This means I can't patch my Linux kernel for my Android tablet.
Thanks ARM! The tablet manufacturers might have modified the sources and just closed them.
The kernel modules don't comply with GPLv2 as they should. So it's not possible to get custom ROM's on that tablet with legal investments.
Thanks ARM again for closed source even the modules, which is a really bad thing. Opensource and ARM GPU's are not complying.
Full kernel source for all of our driver releases is available here, and is distributed under the GPLv2 license:
Cheers, Pete
Peter Harris
Thanks for your time! It's really nice that you help me out. I want to use the mali kernel driver sources with the Amlogic modifications inside r1p0. I got now some variables like ump_dd_phys_block_count_get , ump_dd_reference_release , ump_dd_phsy_blocks_get and ump_dd_handle_create_from_secure_id which are missing contents. Where do I find the information to fill these variables?
I have even tried to compile ump first and then mali but it's not the problem I think.
I've now compiled the mali sources again and got errors which are maybe the relevant thing that's why mali.ko doesn't work?
I did this command:
make modules SUBDIRS=drivers/amlogic/mali/
The errors are:
WARNING: "ump_dd_phys_block_count_get" [drivers/amlogic/mali//mali.ko] undefined! WARNING: "ump_dd_reference_release" [drivers/amlogic/mali//mali.ko] undefined! WARNING: "ump_dd_phys_blocks_get" [drivers/amlogic/mali//mali.ko] undefined! WARNING: "ump_dd_handle_create_from_secure_id" [drivers/amlogic/mali//mali.ko] undefined!
Does anyone have an idea what might be wrong?
Thanks for help. It will be so nice to have this issue solved!
Regards
Johannes
The UMP driver is a separate kernel module, and is distributed in the "Open Source Mali Utgard GPU Kernel Drivers" driver download on the page I linked to earlier. See inside the "driver\src\devicedrv\ump\" directory in the bundle.
Note that not every platform needs UMP - the memory backend is configurable. Also note that in many cases UMP needs platform specific configuration settings if the platform is using a memory carve-out for display memory (not all display controllers can cope with random 4KB pages, and must have physically contiguous memory allocations for displayable buffers).
I'll be honest and say this isn't my area of expertise - I'll try and find someone who can help - although in most cases we don't know the configuration and/or modifications used by the device manufacturer so there is some risk that we may not be able to be much assistance.
HTH, Pete
thanks for tying to help me with this. The kernel device tree is here: http://www.intenso.de/downloads.php?kategorie=33&produkt=1322562274 The mali kernel module is located in /drivers/amlogic/mali . It's having customizations inside. The source code from the Intenso GmbH must be somehow broken. The kernel is working but what is the use on a tablet without a GUI? Makes no profit. I'm thinking that the Intenso GmbH knowingly distributed the kernel not tested if it's complete. The thing I see is that the original kernel got build by someone from China so Intenso might never have compiled the kernel but have distributed them. It looks like that the device manufacturer Yifangdigital does provide a service that they compile the kernel. Even the bootloader got compiled from them. And I'm sure that Yifangdigital gives a f*** about to comply with the GPL. The devices should just get sold and make money. Behind open source and some companies is just ti make money. Doesn't matter if a lizence is not being compiled.
zwzhu@midcs-desktop looks like yifangdigital
If we can't get the mali.ko module as a working one compiled, I will just build the whole 3.0.8-ge9ca3e2 kernel around the module. In my stock Android ROM are mali.ko and ump.ko precompiled of course I'll use the mali.ko then. But the kernel is not complying with GPL so LineageOS is impossible... I'm going to have a stock KitKat running on that device stable. Luckily AOSP is Apache 2.0.
I think I got it solved now. I've taken from an Amlogic 8726-M3 kern source the Mali directory and replaced it with the Mali directory inside my Amlogic 8726-MX/M6 kernel.
So now I have a single core mali module instead of the dualcore version.
Does the Mali GPU now perform in single core or in dual core mode? I haven't changed the library drivers, so the Mali GPU should be able to run in a dual core mode by the library drivers, but do the new modules limit it to single core mode?
Thanks for reply.
Regards,
