AC/DC bidirectional battery charger/discharger Firmware/Hardware simulation
My project diagram is similar to this idea,
Lets  say input is 3p 380VAC, 60Hz, Main Transformer MTR runs at 20kHz, DC output should be 50-147 v, charging current 100A. Should have CC and CV mode of operation.
I need to implement FW with following facilities,
1. Shunt/ Temperature sensing
2. 3v AC to 16 bit ADC having channel current and voltage
3. CAN/SPI/SCI protocol
4. PF correction, PI or PID control
5. PWM for high frequency switching.
KIndly suggest any simulation model/ EVM board/tools to understand the system.
There are no posts to show. This could be because there are no posts in this forum or due to a filter.
