I have installed the Cortex-A5x4 FVP but I cannot find it in the DS-5 debug configuration. How can I run it?
Not sure why it's not already in the debug configuration. I imported it by following this guide: http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0446z/vvi1403112275165.html. Everything works now.
This is not a known FVP in DS-5, and so you will need to create a new one. Don't worry, this is straight forward. Select File > New > Other, and locate Model Configuration
Select (or create a new) configuration database in which to store this configuration
Then locate where you have installed this model
Config will be created (screenshot below taken with a different FVP, but procedure is the same) - edit name etc if appropriate, and click Import. This configuration will now be available for you to use as any other model configuration.
Note this is a 'do once' task.
Hope that helps
View all questions in Simulation Models forum
