AXI5 : Untranslated Transactions property for A*MMU* signals and similarly for AXI5-Lite for AWSTASH*
I'm trying to add some checks for AXI5 / AXI5 -Lite protocol.
When Untranslated Transaction is TRUE, do all of the signals
A[R/W]MMUSECSID
A[R/W]MMUSID
A[R/W]MMUSSIDV
A[R/W]MMUSSID
A[R/W]MMUATST
need to be defined and used together.
For example, if I didn't have the ARMMUSECSID and AWMMUSECSID defined in the AXI5 protocol would the protocol still work correctly ?
Basically, once Untranslated Transaction is defined to be TRUE , do all of the A*MMU* signals need to be defined together ?
(FALSE) None or (TRUE) ALL signals.
And similarly for AXI5-Lite  AWSTASH* signals.
If Cache_Stash_Transactions is TRUE, do all AWSTASH* signals need to be defined on the AXI5-Lite protocol ?
One cannot leave out one of the signals from the set {AWSTASHID, AWSTASHIDEN, AWSTASHLPID, AWSTASHLPIDEN}.
Thanks,
David
  • Basically, once Untranslated Transaction is defined to be TRUE , do all of the A*MMU* signals need to be defined together ?
    This is partially described in E2.12.2 and Table F2-2 in the AMBA Specifications.
    In general, the AxMMU* signals are optional if the Untranslated_Transactions property is defined, and not allowed if the property is not defined. The exceptions are:
    "All signals are optional with defined default values, with the restrictions:
    • ARMMUSSID and ARMMUSSIDV must either be both present or both absent.
    • AWMMUSSID and AWMMUSSIDV must either be both present or both absent."
    Information can be found in E2.2.2.
    "The following rules apply to the AW channel signaling associated with the Cache_Stash_Transactions property:
    • AWSTASHNID and AWSTASHNIDEN must either be both present or both absent.
    • AWSTASHLPID and AWSTASHLPIDEN must either be both present or both absent."
    The AWSTASHNID/AWSTASHNIDEN are expected to be present in most cases, unless there is only one possible target for the stash request.
