Hello everyone. I'm trying to understand how to create and make work two separate baremetal programms on two cores of cortex-a9. I'm using Cyclone V SoC. DS-5, arm compiller 5, DE1-SoC board by terasic. I already understand how to work with main core (cpu0) and how to make baremetal application for it. But I can't find any info about how to run second core (cpu1). I understand that it should be done from software. Should I create two separate applications in DS-5 for each core? Or should it be done in one project but with tricky code placement? Maybe someone have experience with this? I've read Cyclone V HPS tech ref manual, Cortex-A9 MPCore tech ref malual and still can't find an answer. Moreover there is so little info about behaviour of second core (cpu1) after releasing reset signal.
View all questions in SoC Design forum
