AMBA AHB Trace Macrocell (HTM)
Hello All
I'm interested in the AMBA AHB Trace Macrocell (HTM). I want to use it to trace None-Core-Masters (e.g. DMA) in an AHB multilayer matrix based system. However, I have 2 questions which make me hesitate.
1. The HTM ssems to be pretty old. Is it still offered by ARM? And is it compatible with the up to date coresight soc-400?
2. The HTM does'nt seem to have the possibility for timestamps. However, on my research for traceing I got the opinion that timestamps are something you want to have wenn having multiple trace sources. Any ideas?
Thanks you,
Jogi
  • The AMBA Advanced High-performance Bus system connects embedded processors such as an ARM core to high-performance peripherals, DMA controllers, on-chip memory, and interfaces. It is a high-speed, high-bandwidth bus that supports multi-master bus management to maximize system performance.
    first call online login
