Dear All,
My question is very basic : how should I fix this error when compiling ClockDiv_XilinxS6.v on Nexys3 ? how i should change this verilog code ? the answer recored 56113 don't provide the needed code just only the technical/schematic solution.
Error : PhysDesignRules:2502 - Issue with pin connections and/or configuration on block:<uClockDiv/uBUFIO2>:<BUFIO2_BUFIO2>. BUFIO2 has an invalid setting of DIVIDE by 2. This setting is not supported. For more information please see Answer Record 56113.
Problem fixed by creating new Ip instead of clockDiv_XlinixS6.V : delete existent uclockdiv. Then create new IP : New source, IP (core generator), name: ClockDiv. Use wizard to create a simple clock div with only input(100MHz) and output (50 MHz)
View all questions in SoC Design forum
