I'm not sure if this is the right forum to post this in.
I understand the ICode/Dcode fetch over the same memory range. And ICODE would be the assembly instructions that will be executed ie. pointed by the PC
Also lets assume ICode/Dcode goes to FLASH.
Is there an example on what is actually fetched through DCODE in a typical program?
Would it be read only data where it is declared as constant in C otherwise I am assuming all variables should be fetched from the SRAM (RW variable).
From a compiler perspective, what will cause it to compile data accesses to the Dcode address vs to the SRAM instead.
Thanks in advance.
View all questions in SoC Design forum
