Compare the performance of In-order and Out-of-order in AXI protocol
I am checking the performance of an SoC system.
Currently, I am facing an issue as below:
I have 1 master access to 1 slave (OS = 8).
Assume that I have 3 packages:
A0 (ID = 0), A1(ID = 1), A2 (ID = 2).
In this case, the system supports out-of-order and I get the BW = 12 MB/s.
If I have 3 packages as below:
A0 (ID = 0), A1(ID = 0), A2 (ID = 0).
In this case, The system supports in-order (Because of same ID) and I get the BW = 14 MB/s.
I am very confused because of the difference between BW in two cases, Any body help me explan the reason ?
