Hi
I am using 3 instances of Cortex M3.. I would like to bring only one JTAG/SW interface to external ports. Please let me know if ARM has any IP which multiplexes JTAG/SW interfaces in RTL.
madduri
HI madduri,
I have the same question. Did you find a solution in the meantime ?
Thanks for your help
br
Heinz
M3 Comes with DAP Bus Slave,being the debug access port( correct me if I am wrong).
Using a SWJDP->DAPBUSIC->M3x3 would serve your purpose.
let me know if it helps
Kind Regards
JTAG is designed to work in a chain ...
