where are the C++  libraries for linux app?
I have an Altera Cyclone V SoC DevKit that came with the ARM DS-5 tools.  I have been running the Hello World C linux app examples that came with the tools.  I want to run a similar C++ linux app example, so I copied the C example project (as I have several times before) but this time renamed the main.c file as main.cpp.  Everything compiled okay.  Then I added #include <iostreams>  and the build broke.
**** Build of configuration Default for project helloCpp ****
make all
if not exist stripped mkdir stripped
arm-linux-gnueabihf-gcc main.o -o hellocpp -marm -march=armv4t -mfloat-abi=soft
main.o: In function `__static_initialization_and_destruction_0':
c:\altera\13.1\embedded\ds-5\sw\gcc\bin\../lib/gcc/arm-linux-gnueabihf/4.7.3/../../../../arm-linux-gnueabihf/include/c++/4.7.3/iostream:75: undefined reference to `std::ios_base::Init::Init()'
main.o: In function `_GLOBAL__sub_I_main':
C:\Dev\DS-5 Workspace\helloCpp/main.cpp:23: undefined reference to `std::ios_base::Init::~Init()'
collect2.exe: error: ld returned 1 exit status
make: *** [hellocpp] Error 1
**** Build Finished ****
I've attached the main.cpp and the makefile.  The makefile I hardwired the main.o target, and disabled the $(OBJS) targets, to force usage of the C++ compiler.  Otherwise the makefile is what I found in the \hello example project.
My first suspicion is that there is an #include path issue.  I had already added all the #include paths I found in the \gnometris project, which was the only C++ example project I could find.  Is there one missing?
Second suspicion is a library path issue.  However, I noted the \gnometris project did not specify any libraries.  What libraries should be included for this?
Third (actually the strongest suspicion) there is something wrong with the makefile.  Is there a simple C++ example project that will compile with the Cyclone V DS-5 tools?
6509.zip
