CPUIdle Marvell SoC
I'm facing an issue with some of the linux kernel code. I'm trying to use the CPU suspend fonction (located in arch/arm/kernel/sleep.s) of the linux next kernel
The code is the following:
     * Save CPU state for a suspend.  This saves the CPU general purpose
     * registers, and allocates space on the kernel stack to save the CPU
     * specific registers and some other data for resume.
     *  r0 = suspend function arg0
     *  r1 = suspend function
     *  r2 = MPIDR value the resuming CPU will use
    ENTRY(__cpu_suspend)
        stmfd    sp!, {r4 - r11, lr}
    #ifdef MULTI_CPU
        ldr    r10, =processor
        ldr    r4, [r10, #CPU_SLEEP_SIZE] @ size of CPU sleep state
    #else
        ldr    r4, =cpu_suspend_size
    #endif
        mov    r5, sp            @ current virtual SP
        add    r4, r4, #12        @ Space for pgd, virt sp, phys resume fn
        sub    sp, sp, r4        @ allocate CPU state on stack
        ldr    r3, =sleep_save_sp
        stmfd    sp!, {r0, r1}        @ save suspend func arg and pointer
        ldr    r3, [r3, #SLEEP_SAVE_SP_VIRT]
        ALT_SMP(ldr r0, =mpidr_hash)
        ALT_UP_B(1f)
        /* This ldmia relies on the memory layout of the mpidr_hash struct */
        ldmia    r0, {r1, r6-r8}    @ r1 = mpidr mask (r6,r7,r8) = l[0,1,2] shifts
        compute_mpidr_hash    r0, r6, r7, r8, r2, r1
        add    r3, r3, r0, lsl #2
    1:    mov    r2, r5            @ virtual SP
        mov    r1, r4            @ size of save block
        add    r0, sp, #8        @ pointer to save block
        bl    __cpu_suspend_save
        adr    lr, BSYM(cpu_suspend_abort)
        ldmfd    sp!, {r0, pc}        @ call suspend fn
    ENDPROC(__cpu_suspend)
        .ltorg
    cpu_suspend_abort:
        ldmia    sp!, {r1 - r3}        @ pop phys pgd, virt SP, phys resume fn
        teq    r0, #0
        moveq    r0, #1            @ force non-zero value
        mov    sp, r2
        ldmfd    sp!, {r4 - r11, pc}
    ENDPROC(cpu_suspend_abort)
This code appears to follow the standard procedure described in the following ARM document:
http://www.google.fr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCAQFjAA&url=http%3A%2F%2Ffr.slideshare.net%2Flinaroorg%2Fidling-ar-msinabusyworld&ei=7f_ZU_TnIeuV0QXW74DoDg&usg=AFQjCNEVnPO_e_2aYi2Q_4BMthr1Bp-AtA&sig2=NGAYgxTY_MIB1qA3_zeBcA&bvm=bv.72185853,d.d2k
I'm not so familiar with ARM assembly, but I understand that the code is saving the register states on the stack, and then enter the subroutine cpu_suspend_save to flush L1 and L2 cache memory.
When the programm is entering the __cpu_suspend save function, the CPU get lost in it and that turns into a kernel panic. Do you see a reason for such a thing ? Flushing the L1 and L2 cache could be the reason ?
