Bus Matrix
Note: This was originally posted on 28th January 2009 at http://forums.arm.com
What exactly is a bus matrix? I came across the term in ARM cortex M3 specs but couldnt find any proper description. Can someone help?
  • Note: This was originally posted on 31st January 2009 at http://forums.arm.com
    ...And what is the point of this kind of an arrangement?
    The bus-matrix on the Cortex-M3 is a basic arbiter and router, connecting three sources of transactions (load/stores from the core, instruction fetches from the core and debug read/writes from the debug access port) to the M3's four destinations, the instruction and data code busses, the system bus and the NVIC/private-peripheral space.
    In the best case this should allow multiple transactions to be handled simultaneously, e.g. instruction fetch from instruction-code-bus in parallel with data store to system bus; in the worst case it ensures that simultaneous requests from multiple sources to the same destination occur in the correct order based upon the priority assigned to the source.
    hth
    s.
    hth
    s.
