Hi friends, I came across a problem with my UART communication.My codes are below.if I userx_buffer = (uint8_t*)calloc(3,sizeof(uint8_t)); HAL_UART_Receive_IT(&huart1,&rx_data,1); and rx_buffer = (uint8_t*)realloc(rx_buffer,sizeof(uint8_t));program works , but if I use these codesrx_buffer = (uint8_t*)calloc(10,sizeof(uint8_t));HAL_UART_Receive_IT(&huart1,&rx_data,1); and rx_buffer = (uint8_t*)realloc(rx_buffer,sizeof(uint8_t));it doesn't work,I changed 10 instead of 3 in calloc. As much as I remembered stm32f103 stop to work after the first sending data.probably hardfault.I couldn't debug because of limited USB input.
#include "main.h"#include "stm32f1xx_hal.h"#include "usart.h"#include "gpio.h"#include "stdlib.h"
void SystemClock_Config(void);static void MX_NVIC_Init(void);void Clear_Buffer(void);
uint8_t rx_data=0; uint8_t *rx_buffer; uint8_t rx_index=0; uint8_t dataReady=0; uint8_t length=0;
int main(void){ HAL_Init(); SystemClock_Config();
MX_GPIO_Init(); MX_USART1_UART_Init(); MX_USART2_UART_Init();
MX_NVIC_Init();
rx_buffer = (uint8_t*)calloc(3,sizeof(uint8_t)); HAL_UART_Receive_IT(&huart1,&rx_data,1); while (1) { Clear_Buffer(); }
}//****************************************************************************//void Clear_Buffer(void){ if(dataReady) { dataReady = 0; for(int i=0;i<length;i++) rx_buffer[i] = NULL; free(rx_buffer); rx_buffer = (uint8_t*)calloc(3,sizeof(uint8_t)); }}//Bu interrupt fonksiyonuna ait prototip zaten oldugundan ayrica tanimlamaya gerek yokturvoid HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart){ if(huart->Instance == USART1) { HAL_GPIO_TogglePin(GPIOC,GPIO_PIN_13); if(rx_data != 13) { rx_buffer[rx_index++] = rx_data; rx_buffer = (uint8_t*)realloc(rx_buffer,sizeof(uint8_t)); } else { length = strlen(rx_buffer); //Gönder HAL_UART_Transmit(&huart1,rx_buffer,length,1000);
dataReady = 1; rx_index = 0;
} HAL_UART_Receive_IT(&huart1,&rx_data,1); }}
It's no PC with "unlimited" memory, so you have to restrict the input data anyway. So why not have a fixed buffer.
malloc/calloc == evil => search for "fragmentation"
In embedded systems one should avoid the use of malloc()/free().
What do you mean ,statically? ,if a person want to enter lots of data ,it can be entered ,what I want to do .Also why do you say they were evil,Could you explain it ?
Did you try to allocate the buffer statically? (calloc/malloc are evil!)
View all questions in SoC Design forum
