Hello ,
I am new to ARM cortex M processors and while doing some coding on my board using KEIL i found that
at location 0x0000_0000 my debugger shows the value "0x2000_0660" . Thats the value of the MSP loaded.
but i really dont understand how linker arrived at that value using __initial_sp
i checked in the startup file and found this
; Amount of memory (in bytes) allocated for Stack; Tailor this value to your application needs; <h> Stack Configuration; <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>; </h>
Stack_Size EQU 0x00000400
AREA STACK, NOINIT, READWRITE, ALIGN=3Stack_Mem SPACE Stack_Size__initial_sp
How this turns out to be __initial_sp = 0x2000_0660 ???
Please help to understand this .
The stack would normally come after and .data or .bss section (I'm not sure why, if you're going to allocate a fixed-size stack anyway. for "historical" reasons, perhaps - in a traditional small-memory microcontroller .data,.bss, and the heap would start at the beginning of memory and grow upward, while the stack would start at the end of memory and grow downward, and you'd "hope" that they never collided.)
Thanks Bill
ok , so my RAM starts at 0x2000_0000
stack size is 0x400 and stack ends at 0x2000_0660( stack moves backward from here )
that means , from 0x2000_0000 to 0x2000_0260 is a place for .data , .bss and heap ?
Which file will contain this info, i checked scatter file and couldn't able to obtain these sizes.
Sounds right. I think Keil produces a "memory map" output (or can certainly be configured to do so.)
The old class project I have (UV5 on MSP432 launchpad) pops up the info when I double click on the "Target 1" in the project explorer (YMMV - I'm not too familiar with Keil.) Somewhere in there there are some lines that look like:
Image Symbol Table Local Symbols Symbol Name Value Ov Type Size Object(Section) RESET 0x00000000 Section 324 startup_msp432p401r_uvision.o(RESET) : .data 0x20000000 Section 4 main.o(.data) .bss 0x20000004 Section 96 libspace.o(.bss) HEAP 0x20000068 Section 0 startup_msp432p401r_uvision.o(HEAP) STACK 0x20000068 Section 512 startup_msp432p401r_uvision.o(STACK) Heap_Mem 0x20000068 Data 0 startup_msp432p401r_uvision.o(HEAP) Stack_Mem 0x20000068 Data 512 startup_msp432p401r_uvision.o(STACK) __initial_sp 0x20000268 Data 0 startup_msp432p401r_uvision.o(STACK)
View all questions in Embedded forum
