D-Cache read problem in EL2 mode ARM V8
I am working on  EL2 mode ARM V8 ,
Problem I am facing when I enable D-cache then I am not able to read the data.
My boot flow is EL3 to EL2 and in EL2 snippet of code is below
1 stp x29, x30 [sp,#32]
2 mrs     x0, sctlr_el2
3 orr     x0, x0, #CTRL_C_BIT
4  msr     sctlr_el2, x0
5 ldp x29, x30 [sp,#32]
Here  I checked all x30, sp etc are valid and point to valid memory and this DDR location is accessible from other core.
After line 4, at line 5 I am getting random values in x29, x30
In case i comment lune 4, then boot works fine,
I am wondering , why this enable cache is leading to bad behavior
FYI,
If I stay in EL3 mode only then changing above code like
2 mrs     x0, sctlr_el3
4  msr     sctlr_el3, x0
works fine as well.
Thanks for help, why enabling d-cache in EL2 mode is leading to random/corrupted values
thx
There are no posts to show. This could be because there are no posts in this forum or due to a filter.
