BUSY transfer and WAIT state both are using the same time ,How to perform the AHB?
Hi sir,
       T1=NON-SEQ
       T2=BUSY
       T3=SEQ
       T4=SEQ
      T5= SEQ
         This is for WRITE operation:
         i am  using a BUSY state for T2. Then my WAIT state for till T3.  I have read from the forum if WAIT state u are using a BUSY transfer, you can change next clock on the  valid transfer.
         If i change the HTRANS to the valid transfer my T1 data will  be maintained for till T3 clock. Then what about the BUSY transfer.
       This same as applicable for READ operation.And this is only for WAIT STATE.
 Regards
 Rajaraman R
  • Just so that I fully understand what you are describing, could you draw a diagram, or explain what you are driving HREADY to in each clock cycle ?
    It looks like you might be describing HREADY driven low in cycle T2 coinciding with the BUSY transfer address phase, in which case the following would apply.
    You can change HTRANS at the start of T3 to SEQ. During the T2 and T3 cycles, the HWDATA bus will have the T1 transfer write data. For a read transfer the HRDATA value is undefined for cycle T2 because the slave is signalling a wait state, but would be the requested read data in cycle T3.
    In this scenario the BUSY cycle is never sampled by the system (because it was never seen on HTRANS at the same time as HREADY being high), so essentially the BUSY transfer never happened
