Hello everyone,
Can anyone help me how do I combine function attributes?
I need to use __attribute__(used) and __attribute__(section("xuz")) function attributes while defining a function.
Thanks in advance!
Any of the following three styles should work:
__attribute__((used)) __attribute__((section("xyz"))) int foo(void) { return 42; } __attribute__((used,section("abc"))) int bar(void) { return 43; } int toto(void) __attribute__((used,section("def"))); int toto(void) { return 44; }
Further details of the __attribute__ syntax are available here: https://gcc.gnu.org/onlinedocs/gcc/Attribute-Syntax.html
Simon.
Thank you.
View all questions in Embedded forum
