How do i configure vector table for cortex A-57?
From the documents - "The vector table has 16 entries, with each entry being 128 bytes (32 instructions) in size. The table effectively consists of 4 sets of 4 entries"
Also " Virtual address of each table base is set by the Vector Based Address Registers VBAR_EL3, VBAR_EL2 and VBAR_EL1.".
So, do i need different vector table for each exception level EL0, EL1, EL2 and EL3? Am i to set the same vector base address for all the above base address registers?
Or Is it like, each set of 4 entries in the vector table belong to a particular exception level?
Please help, I am really confused now.
Regards,
Ajeesh
Hi, Thanks for the reply.. What if i need to execute my code in only the lowest exception level? Does the code automatically goes to a higher exception level when an interrupt occurs or does the user have to do it manually(like CPS in v7)? When the board starts up, At what level or mode will it be working on? Also, Is it okay if i use the same vector table for the all the exception levels, EL1, EL2 and EL3? regards, Ajeesh
View all questions in Embedded forum
