what is the difference between these thing firmware ,boot loader and driver.
hi all,
i want to difference between following three things.
i)Firmware
ii)Bootloader
iii)Driver.
in my view
  Firmware - used to control one particular chip or used to transfer the data from one protocol to other type protocol.
Bootloader - used to allow the downloaded code from particular memory address.
  Driver - used to access particular device.
pls help me.
thanks in advance..........
  • Hello,
    I moved your question to Embedded.
    Here are how I would personally describe them:
    1. Firmware: a small footprint software usually found in embedded devices. For instance, the micro-code of a hard-drive or a washing machine.
    2. Bootloader: part of the firmware usually ran during the boot sequence which allows to load a new firmware to update it from SPI, USB, CAN...
    3. Driver: low level reusable set of functions used to run peripherals or work with APIs making some abstraction of the hardware. For instance, sending a function that will handle sending a character through a UART by enabling the module, setting I/Os, baudrate, parity, and then finally sending the character and handling errors.
    How does that sound?
    Alban
  • Hello,
    Alban
