I'm making test some on the famous LPC1114FN28 is there somebody who have some experience about it ?Please, thank for sharing here
Here is the beast
And the pinout informations
I have used it in a few projects (but not with the mbed board. I've ordered that but it hasn't arrived yet.), and I like it
I don't see any other ARM microcontrollers in DIP package (easy to work with on breadboards, and easy to solder).
A few things not perfect:
It would be nice to see more DIP package devices which make life easier for students and hobbyists, but I do understand that DIP packages is actually more expensive to make.
regards,
Joseph
For sure Joseph,
I think the i/o pins are enough for small embedded projects, and DIP allow homemade production for those who don't have the equipement, or skill to realize the PCB with small weldings.
Yes, most of the small projects are fine with this package. (When considering power, crystal and debug pins, there are still 20 pins).
But as soon as the project has a 7 segment LED display (e.g. a 4 digits display with decimal points will take 12 pins), that used most of it.
I used something similar for my own projects.
However, when using it as an educational tool, trying to explain to begineers about the initialization sequence for such display could be a bit hard.
(Also, it is more than 3 pins - SCLK, MOSI, CS, D/C, RESET, optionally MISO).
For the tiny project with educational, i use the famous DIP 8 LCP810 or Or Mbed ST nucleo like to explain the link between electronic & computer science. But a 20 pins is more usefull for demonstration.
Yes, I know 7-segment (LEDs) are simpler and easier to work with and you either have to set up the SPI or toggle the I/O pins manually.
-But it's good when you need to save pins.
Since there are very few Cortex-based DIP, it might be a good idea to acquire an I/O-expander (these exists in DIP as well).
I/O-expanders can be connected via I2C or SPI, depending on the type.
You usually get 8 or 16 extra I/O pins that way, and you can add up to 8 I/O-expanders from one vendor and 8 I/O expanders from another vendor (because the addressing often differ) if required. Example: Use 8 I/O-expanders from NXP and 8 I/O-expanders from Microchip. Let's see, that gives us 16*16 extra pins at the cost of 2 I2C pins, which means we get 254 extra pins... And we'll of course use a lot more power.
View all questions in Embedded forum
