Hi guys.
I have the following problem. In my code I have to assign a structure pointer to uint8_t pointer so I can write into the structure byte by byte. Both are pointers that point to data of different types. Why I cant assign them each other. I am using IAR embedded workbench free size limited version. I tried with other compilers and there was no such problem.
Here is a screen shot of the scenario:
Please help.
Hi rikotech,
you should make type cast of the pDate.
pstr = (unit8_t *)pDate;
would be OK.
Best regards,
Yasuhiko Koumoto.
Thank you Mr. Koumoto - it works now
View all questions in Embedded forum
