Jumping to main application from boot fails on arm cortex m4
Hi Experts,
I need your help...
Actually i am work on a multicore controller, the master core loads the application for the slave core(cortex M4)..
Now when the slave core starts, it executes c_int00 (boot file) and from there it will jump to main application..
The problem is, after rebooting the board multiple times, at some point the control is not jumping to main application,
and instead stays in an infinite loop in the boot file.
Could you please help me to sort this issue...
What could be the reason for such behavior ?
Thanks and Regards
ZbinAhmed
