Hi Experts,
I need your help...
Actually i am work on a multicore controller, the master core loads the application for the slave core(cortex M4)..
Now when the slave core starts, it executes c_int00 (boot file) and from there it will jump to main application..
The problem is, after rebooting the board multiple times, at some point the control is not jumping to main application,
and instead stays in an infinite loop in the boot file.
Could you please help me to sort this issue...
What could be the reason for such behavior ?
Thanks and Regards
ZbinAhmed
Duplicate:
https://community.arm.com/developer/ip-products/processors/f/cortex-m-forum/45728/cortex-m4-boot-issue
Hi Andy,
Do you have any suggestions.
What do you mean by Duplicate ?
Hello Ahmed,
Andy has pointed out that you have opened the same case twice. Please refrain from doing that. As there are other answers here as well, I will not delete this thread as it will be usually done with duplicates.
Kind regards,
Christopher
Hello Christopher,
sorry for that. will try this mistake won't happen again.
View all questions in Embedded forum
