Hi
I have made images to be visible in TFT using sample codes from github for nuvoton
I am using N9H30 series evaluation board,In this series I have dumped only sample code
but that image is also not good.And secondly the frame window is moved a little right .
Please give me your suggestions to proceed further.
Thanks in advance
Hi
I have found the answer.Actually I have forgotten to note that
I have to define color as RGB 565 format.
After doing that code gives good 16 bit resolution colored output
with images and texts.
View all questions in Embedded forum
