CMSIS FIR filter using real time input from ADC and displaying output on DAC not working properly
I am new to this forum and I am facing some difficulty in my program. I am taking ADC input from a DSO- a sine wave at 1kHz frequency, and I am processing the received data and applying filters to the received data and sending output on DAC. I am using both ADC and DAC using DMA. Sampling frequency of ADC and DAC is 8kHz. ADC DMA buffer is circular while DAC DMA is normal that I am re-starting the DMA irq handler. I have generated filter coefficients using FDA tool in MATLAB. The data that I am receiving on the DSO is very distorted. I am using the STM32L476 Discovery Board. I have written the code in Atollic Truestudio using STM32CubeMX. I don't know exactly what is wrong here. The code is written below. What changes should I make to the code to make this code work?
main.c :
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* <h2><center>&copy; Copyright (c) 2019 STMicroelectronics.
* All rights reserved.</center></h2>
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "stdbool.h"
#include "audio.h"
#include "cs43l22.h"
#include "kaiser_10000_order20.h"
#include "arm_math.h"
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
#define ADC_CALIBRATION_TIMEOUT_MS ((uint32_t) 1)
#define ADC_ENABLE_TIMEOUT_MS ((uint32_t) 1)
#define ADC_DISABLE_TIMEOUT_MS ((uint32_t) 1)
#define ADC_STOP_CONVERSION_TIMEOUT_MS ((uint32_t) 1)
#define ADC_CONVERSION_TIMEOUT_MS ((uint32_t) 500)
#define ADC_DELAY_CALIB_ENABLE_CPU_CYCLES (LL_ADC_DELAY_CALIB_ENABLE_ADC_CYCLES * 32)
#define ADC_CONVERTED_DATA_BUFFER_SIZE ((uint32_t) 256)
/* Init variable out of expected ADC conversion data range */
#define VAR_CONVERTED_DATA_INIT_VALUE (__LL_ADC_DIGITAL_SCALE(LL_ADC_RESOLUTION_12B) + 1)
/*DAC Private define ---------------------------------------------------------*/
/* Size of array containing DAC waveform samples */
#define WAVEFORM_SAMPLES_SIZE ADC_CONVERTED_DATA_BUFFER_SIZE
#define AUDIO_I2C_ADDRESS ((uint16_t) 0x94)
#define I2c1Timeout 3000
#define NUM_TAPS BL
#define BLOCK_SIZE 2
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
I2C_HandleTypeDef hi2c1;
SAI_HandleTypeDef hsai_BlockA1;
DMA_HandleTypeDef hdma_sai1_a;
/* USER CODE BEGIN PV */
AUDIO_DrvTypeDef *audio_drv;
__IO uint16_t aADCxConvertedData[ADC_CONVERTED_DATA_BUFFER_SIZE]; /* ADC group regular conversion data */
/* Variables for ADC conversion data computation to scaled values */
float32_t aADCConvertedData_Scaled[ADC_CONVERTED_DATA_BUFFER_SIZE];
/* Variables for FIR Filter Output Data */
float32_t aFilteredData[ADC_CONVERTED_DATA_BUFFER_SIZE]; /* FIR Filter Output Values (array of data) */
/* Variables for storing FIR filtered values */
static int16_t finalOutput[ADC_CONVERTED_DATA_BUFFER_SIZE];
/* Variable flag to check the status of ADC Conversion*/
static bool dacStartFlag = true;
volatile bool adcHalfConversionComplete = false;
volatile bool adcFullConversionComplete = false;
static float32_t firStateF321[68];
/*Variable for number of blocks based on buffer size and block size*/
uint32_t numBlocks = ADC_CONVERTED_DATA_BUFFER_SIZE/BLOCK_SIZE;
/*Pointers for handling ADC data and filter data buffer */
float32_t *aADCConverted_Full_Scaled_Ptr, *aADCConverted_Half_Scaled_Ptr, *aFilteredData_Half_Ptr, *aFilteredData_Full_Ptr;
int16_t PlayBuff[ADC_CONVERTED_DATA_BUFFER_SIZE];
volatile int16_t UpdatePointer = -1;
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_DMA_Init(void);
static void MX_SAI1_Init(void);
static void MX_I2C1_Init(void);
static void MX_ADC1_Init(void);
static void MX_TIM15_Init(void);
static void MX_DAC1_Init(void);
static void MX_TIM7_Init(void);
/* USER CODE BEGIN PFP */
void AdcDmaTransferComplete_Callback();
void AdcDmaTransferHalf_Callback();
void Activate_ADC(void);
void Activate_DAC(void);
void Configure_DMA(void);
void AdcGrpRegularOverrunError_Callback(void);
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
//#define blockSize BLOCK_SIZE
uint32_t tmp_index_adc_converted_data = 0; //Variable for ADC operation loop index
aADCConverted_Half_Scaled_Ptr = &aADCConvertedData_Scaled[0]; //Assigning ADC buffer starting element's address
aADCConverted_Full_Scaled_Ptr = &aADCConvertedData_Scaled[ADC_CONVERTED_DATA_BUFFER_SIZE/2];//Assigning ADC buffer middle element's address
aFilteredData_Half_Ptr = &aFilteredData[0]; //Assigning filter buffer starting element's address
aFilteredData_Full_Ptr = &aFilteredData[ADC_CONVERTED_DATA_BUFFER_SIZE/2]; //Assigning filter buffer middle element's address
arm_fir_instance_f32 S;
arm_fir_init_f32(&S, NUM_TAPS, (float32_t *)&B[0], &firStateF321[0], BLOCK_SIZE);
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_DMA_Init();
MX_SAI1_Init();
MX_I2C1_Init();
MX_ADC1_Init();
MX_TIM15_Init();
MX_DAC1_Init();
MX_TIM7_Init();
/* USER CODE BEGIN 2 */
for(int i=0; i < ADC_CONVERTED_DATA_BUFFER_SIZE; i+=1)
PlayBuff[i]=finalOutput[i];
for (tmp_index_adc_converted_data = 0; tmp_index_adc_converted_data < ADC_CONVERTED_DATA_BUFFER_SIZE; tmp_index_adc_converted_data++)
aADCxConvertedData[tmp_index_adc_converted_data] = VAR_CONVERTED_DATA_INIT_VALUE;
Configure_DMA();
//Enable timers of ADC and DAC
LL_TIM_EnableCounter(TIM15);
LL_TIM_EnableCounter(TIM7);
Activate_DAC();
Activate_ADC();
if ((LL_ADC_IsEnabled(ADC1) == 1) &&
(LL_ADC_IsDisableOngoing(ADC1) == 0) &&
(LL_ADC_REG_IsConversionOngoing(ADC1) == 0) )
LL_ADC_REG_StartConversion(ADC1);
else
Error_Handler();
if(0 != audio_drv->Play(AUDIO_I2C_ADDRESS, NULL, 0))
Error_Handler();
if(HAL_OK != HAL_SAI_Transmit_DMA(&hsai_BlockA1, (uint8_t *)PlayBuff, ADC_CONVERTED_DATA_BUFFER_SIZE))
Error_Handler();
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
if(adcFullConversionComplete == true)
if(dacStartFlag == true)
dacStartFlag = false;
LL_DAC_EnableDMAReq(DAC1,LL_DAC_CHANNEL_2);
uint32_t tmp_index = 0;
for (tmp_index = 0; tmp_index < ADC_CONVERTED_DATA_BUFFER_SIZE; tmp_index++)
aADCConvertedData_Scaled[tmp_index] = ((float32_t)aADCxConvertedData[tmp_index] - 2048.0) / 2048.0 ;
for (int i=0; i < (numBlocks); i++)
arm_fir_f32((arm_fir_instance_f32*)&S, aADCConverted_Half_Scaled_Ptr + (i * BLOCK_SIZE), aFilteredData_Half_Ptr + (i * BLOCK_SIZE), BLOCK_SIZE);
//Converting back the filtered data to make it compatible for DAC processing
for (tmp_index =0; tmp_index < ADC_CONVERTED_DATA_BUFFER_SIZE; tmp_index++)
finalOutput[tmp_index] = (int16_t)(aFilteredData[tmp_index] * 2048.0) + 2048;
PlayBuff[tmp_index]=finalOutput[tmp_index];
//Reset ADC Full Conversion flag
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
/** Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
RCC_OscInitStruct.MSIState = RCC_MSI_ON;
RCC_OscInitStruct.MSICalibrationValue = 0;
RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_6;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_MSI;
RCC_OscInitStruct.PLL.PLLM = 1;
RCC_OscInitStruct.PLL.PLLN = 40;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV7;
RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
Error_Handler();
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_SAI1|RCC_PERIPHCLK_I2C1
|RCC_PERIPHCLK_ADC;
PeriphClkInit.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
PeriphClkInit.Sai1ClockSelection = RCC_SAI1CLKSOURCE_PLLSAI1;
PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_PLLSAI2;
PeriphClkInit.PLLSAI2.PLLSAI2Source = RCC_PLLSOURCE_MSI;
PeriphClkInit.PLLSAI2.PLLSAI2M = 1;
PeriphClkInit.PLLSAI2.PLLSAI2N = 40;
PeriphClkInit.PLLSAI2.PLLSAI2P = RCC_PLLP_DIV7;
PeriphClkInit.PLLSAI2.PLLSAI2R = RCC_PLLR_DIV2;
PeriphClkInit.PLLSAI2.PLLSAI2ClockOut = RCC_PLLSAI2_ADC2CLK;
PeriphClkInit.PLLSAI1.PLLSAI1Source = RCC_PLLSOURCE_MSI;
PeriphClkInit.PLLSAI1.PLLSAI1M = 1;
PeriphClkInit.PLLSAI1.PLLSAI1N = 40;
PeriphClkInit.PLLSAI1.PLLSAI1P = RCC_PLLP_DIV7;
PeriphClkInit.PLLSAI1.PLLSAI1Q = RCC_PLLQ_DIV2;
PeriphClkInit.PLLSAI1.PLLSAI1R = RCC_PLLR_DIV2;
PeriphClkInit.PLLSAI1.PLLSAI1ClockOut = RCC_PLLSAI1_SAI1CLK;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
/** Configure the main internal regulator output voltage
if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
Error_Handler();
* @brief ADC1 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
LL_ADC_InitTypeDef ADC_InitStruct = {0};
LL_ADC_REG_InitTypeDef ADC_REG_InitStruct = {0};
LL_ADC_CommonInitTypeDef ADC_CommonInitStruct = {0};
LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
/* Peripheral clock enable */
LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_ADC);
LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOA);
/**ADC1 GPIO Configuration
PA3 ------> ADC1_IN8
GPIO_InitStruct.Pin = LL_GPIO_PIN_3;
GPIO_InitStruct.Mode = LL_GPIO_MODE_ANALOG;
GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
LL_GPIO_Init(GPIOA, &GPIO_InitStruct);
LL_GPIO_EnablePinAnalogControl(GPIOA, LL_GPIO_PIN_3);
/* ADC1 DMA Init */
/* ADC1 Init */
LL_DMA_SetPeriphRequest(DMA1, LL_DMA_CHANNEL_1, LL_DMA_REQUEST_0);
LL_DMA_SetDataTransferDirection(DMA1, LL_DMA_CHANNEL_1, LL_DMA_DIRECTION_PERIPH_TO_MEMORY);
LL_DMA_SetChannelPriorityLevel(DMA1, LL_DMA_CHANNEL_1, LL_DMA_PRIORITY_LOW);
LL_DMA_SetMode(DMA1, LL_DMA_CHANNEL_1, LL_DMA_MODE_CIRCULAR);
LL_DMA_SetPeriphIncMode(DMA1, LL_DMA_CHANNEL_1, LL_DMA_PERIPH_NOINCREMENT);
LL_DMA_SetMemoryIncMode(DMA1, LL_DMA_CHANNEL_1, LL_DMA_MEMORY_INCREMENT);
LL_DMA_SetPeriphSize(DMA1, LL_DMA_CHANNEL_1, LL_DMA_PDATAALIGN_HALFWORD);
LL_DMA_SetMemorySize(DMA1, LL_DMA_CHANNEL_1, LL_DMA_MDATAALIGN_HALFWORD);
/* ADC1 interrupt Init */
NVIC_SetPriority(ADC1_2_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
NVIC_EnableIRQ(ADC1_2_IRQn);
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Common config
ADC_InitStruct.Resolution = LL_ADC_RESOLUTION_12B;
ADC_InitStruct.DataAlignment = LL_ADC_DATA_ALIGN_RIGHT;
ADC_InitStruct.LowPowerMode = LL_ADC_LP_MODE_NONE;
LL_ADC_Init(ADC1, &ADC_InitStruct);
ADC_REG_InitStruct.TriggerSource = LL_ADC_REG_TRIG_EXT_TIM15_TRGO;
ADC_REG_InitStruct.SequencerLength = LL_ADC_REG_SEQ_SCAN_DISABLE;
ADC_REG_InitStruct.SequencerDiscont = LL_ADC_REG_SEQ_DISCONT_DISABLE;
ADC_REG_InitStruct.ContinuousMode = LL_ADC_REG_CONV_CONTINUOUS;
ADC_REG_InitStruct.DMATransfer = LL_ADC_REG_DMA_TRANSFER_UNLIMITED;
ADC_REG_InitStruct.Overrun = LL_ADC_REG_OVR_DATA_PRESERVED;
LL_ADC_REG_Init(ADC1, &ADC_REG_InitStruct);
LL_ADC_DisableIT_EOC(ADC1);
LL_ADC_DisableIT_EOS(ADC1);
LL_ADC_DisableDeepPowerDown(ADC1);
LL_ADC_EnableInternalRegulator(ADC1);
ADC_CommonInitStruct.CommonClock = LL_ADC_CLOCK_ASYNC_DIV1;
ADC_CommonInitStruct.Multimode = LL_ADC_MULTI_INDEPENDENT;
LL_ADC_CommonInit(__LL_ADC_COMMON_INSTANCE(ADC1), &ADC_CommonInitStruct);
LL_ADC_REG_SetTriggerEdge(ADC1, LL_ADC_REG_TRIG_EXT_RISING);
/** Configure Regular Channel
LL_ADC_REG_SetSequencerRanks(ADC1, LL_ADC_REG_RANK_1, LL_ADC_CHANNEL_8);
LL_ADC_SetChannelSamplingTime(ADC1, LL_ADC_CHANNEL_8, LL_ADC_SAMPLINGTIME_2CYCLES_5);
LL_ADC_SetChannelSingleDiff(ADC1, LL_ADC_CHANNEL_8, LL_ADC_SINGLE_ENDED);
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
* @brief DAC1 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN DAC1_Init 0 */
/* USER CODE END DAC1_Init 0 */
LL_DAC_InitTypeDef DAC_InitStruct = {0};
LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_DAC1);
/**DAC1 GPIO Configuration
PA5 ------> DAC1_OUT2
GPIO_InitStruct.Pin = LL_GPIO_PIN_5;
/* DAC1 DMA Init */
/* DAC_CH2 Init */
LL_DMA_SetPeriphRequest(DMA2, LL_DMA_CHANNEL_5, LL_DMA_REQUEST_3);
LL_DMA_SetDataTransferDirection(DMA2, LL_DMA_CHANNEL_5, LL_DMA_DIRECTION_MEMORY_TO_PERIPH);
LL_DMA_SetChannelPriorityLevel(DMA2, LL_DMA_CHANNEL_5, LL_DMA_PRIORITY_LOW);
LL_DMA_SetMode(DMA2, LL_DMA_CHANNEL_5, LL_DMA_MODE_NORMAL);
LL_DMA_SetPeriphIncMode(DMA2, LL_DMA_CHANNEL_5, LL_DMA_PERIPH_NOINCREMENT);
LL_DMA_SetMemoryIncMode(DMA2, LL_DMA_CHANNEL_5, LL_DMA_MEMORY_INCREMENT);
LL_DMA_SetPeriphSize(DMA2, LL_DMA_CHANNEL_5, LL_DMA_PDATAALIGN_HALFWORD);
LL_DMA_SetMemorySize(DMA2, LL_DMA_CHANNEL_5, LL_DMA_MDATAALIGN_HALFWORD);
/* USER CODE BEGIN DAC1_Init 1 */
/* USER CODE END DAC1_Init 1 */
/** DAC channel OUT2 config
DAC_InitStruct.TriggerSource = LL_DAC_TRIG_EXT_TIM7_TRGO;
DAC_InitStruct.WaveAutoGeneration = LL_DAC_WAVE_AUTO_GENERATION_NONE;
DAC_InitStruct.OutputBuffer = LL_DAC_OUTPUT_BUFFER_ENABLE;
DAC_InitStruct.OutputConnection = LL_DAC_OUTPUT_CONNECT_GPIO;
DAC_InitStruct.OutputMode = LL_DAC_OUTPUT_MODE_NORMAL;
LL_DAC_Init(DAC1, LL_DAC_CHANNEL_2, &DAC_InitStruct);
LL_DAC_EnableTrigger(DAC1, LL_DAC_CHANNEL_2);
/* USER CODE BEGIN DAC1_Init 2 */
/* USER CODE END DAC1_Init 2 */
* @brief I2C1 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN I2C1_Init 0 */
/* USER CODE END I2C1_Init 0 */
/* USER CODE BEGIN I2C1_Init 1 */
/* USER CODE END I2C1_Init 1 */
hi2c1.Instance = I2C1;
hi2c1.Init.Timing = 0x50B03644;
hi2c1.Init.OwnAddress1 = 0;
hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
hi2c1.Init.OwnAddress2 = 0;
hi2c1.Init.OwnAddress2Masks = I2C_OA2_NOMASK;
hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
if (HAL_I2C_Init(&hi2c1) != HAL_OK)
Error_Handler();
/** Configure Analogue filter
if (HAL_I2CEx_ConfigAnalogFilter(&hi2c1, I2C_ANALOGFILTER_DISABLE) != HAL_OK)
Error_Handler();
/** Configure Digital filter
if (HAL_I2CEx_ConfigDigitalFilter(&hi2c1, 0) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN I2C1_Init 2 */
HAL_I2C_MspInit(&hi2c1);
HAL_I2C_Init(&hi2c1);
/* USER CODE END I2C1_Init 2 */
* @brief SAI1 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN SAI1_Init 0 */
/* USER CODE END SAI1_Init 0 */
/* USER CODE BEGIN SAI1_Init 1 */
/* USER CODE END SAI1_Init 1 */
hsai_BlockA1.Instance = SAI1_Block_A;
hsai_BlockA1.Init.Protocol = SAI_FREE_PROTOCOL;
hsai_BlockA1.Init.AudioMode = SAI_MODEMASTER_TX;
hsai_BlockA1.Init.DataSize = SAI_DATASIZE_16;
hsai_BlockA1.Init.FirstBit = SAI_FIRSTBIT_MSB;
hsai_BlockA1.Init.ClockStrobing = SAI_CLOCKSTROBING_FALLINGEDGE;
hsai_BlockA1.Init.Synchro = SAI_ASYNCHRONOUS;
hsai_BlockA1.Init.OutputDrive = SAI_OUTPUTDRIVE_ENABLE;
hsai_BlockA1.Init.NoDivider = SAI_MASTERDIVIDER_ENABLE;
hsai_BlockA1.Init.FIFOThreshold = SAI_FIFOTHRESHOLD_1QF;
hsai_BlockA1.Init.AudioFrequency = SAI_AUDIO_FREQUENCY_8K;
hsai_BlockA1.Init.SynchroExt = SAI_SYNCEXT_DISABLE;
hsai_BlockA1.Init.MonoStereoMode = SAI_STEREOMODE;
hsai_BlockA1.Init.CompandingMode = SAI_NOCOMPANDING;
hsai_BlockA1.Init.TriState = SAI_OUTPUT_NOTRELEASED;
hsai_BlockA1.FrameInit.FrameLength = 32;
hsai_BlockA1.FrameInit.ActiveFrameLength = 16;
hsai_BlockA1.FrameInit.FSDefinition = SAI_FS_CHANNEL_IDENTIFICATION;
hsai_BlockA1.FrameInit.FSPolarity = SAI_FS_ACTIVE_LOW;
hsai_BlockA1.FrameInit.FSOffset = SAI_FS_BEFOREFIRSTBIT;
hsai_BlockA1.SlotInit.FirstBitOffset = 0;
hsai_BlockA1.SlotInit.SlotSize = SAI_SLOTSIZE_DATASIZE;
hsai_BlockA1.SlotInit.SlotNumber = 2;
hsai_BlockA1.SlotInit.SlotActive = 0x00000003;
if (HAL_SAI_Init(&hsai_BlockA1) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN SAI1_Init 2 */
__HAL_SAI_ENABLE(&hsai_BlockA1);
/* Initialize audio driver */
if(CS43L22_ID != cs43l22_drv.ReadID(AUDIO_I2C_ADDRESS))
Error_Handler();
audio_drv = &cs43l22_drv;
audio_drv->Reset(AUDIO_I2C_ADDRESS);
if(0 != audio_drv->Init(AUDIO_I2C_ADDRESS, OUTPUT_DEVICE_HEADPHONE, 90, AUDIO_FREQUENCY_16K))
Error_Handler();
/* USER CODE END SAI1_Init 2 */
* @brief TIM7 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN TIM7_Init 0 */
/* USER CODE END TIM7_Init 0 */
LL_TIM_InitTypeDef TIM_InitStruct = {0};
LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_TIM7);
/* USER CODE BEGIN TIM7_Init 1 */
/* USER CODE END TIM7_Init 1 */
TIM_InitStruct.Prescaler = 99;
TIM_InitStruct.CounterMode = LL_TIM_COUNTERMODE_UP;
TIM_InitStruct.Autoreload = 99;
LL_TIM_Init(TIM7, &TIM_InitStruct);
LL_TIM_EnableARRPreload(TIM7);
LL_TIM_SetTriggerOutput(TIM7, LL_TIM_TRGO_UPDATE);
LL_TIM_DisableMasterSlaveMode(TIM7);
/* USER CODE BEGIN TIM7_Init 2 */
/* USER CODE END TIM7_Init 2 */
* @brief TIM15 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN TIM15_Init 0 */
/* USER CODE END TIM15_Init 0 */
LL_TIM_OC_InitTypeDef TIM_OC_InitStruct = {0};
LL_TIM_BDTR_InitTypeDef TIM_BDTRInitStruct = {0};
LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_TIM15);
/* USER CODE BEGIN TIM15_Init 1 */
/* USER CODE END TIM15_Init 1 */
TIM_InitStruct.ClockDivision = LL_TIM_CLOCKDIVISION_DIV1;
TIM_InitStruct.RepetitionCounter = 0;
LL_TIM_Init(TIM15, &TIM_InitStruct);
LL_TIM_EnableARRPreload(TIM15);
LL_TIM_SetClockSource(TIM15, LL_TIM_CLOCKSOURCE_INTERNAL);
TIM_OC_InitStruct.OCMode = LL_TIM_OCMODE_FROZEN;
TIM_OC_InitStruct.OCState = LL_TIM_OCSTATE_DISABLE;
TIM_OC_InitStruct.OCNState = LL_TIM_OCSTATE_DISABLE;
TIM_OC_InitStruct.CompareValue = 0;
TIM_OC_InitStruct.OCPolarity = LL_TIM_OCPOLARITY_HIGH;
TIM_OC_InitStruct.OCNPolarity = LL_TIM_OCPOLARITY_HIGH;
TIM_OC_InitStruct.OCIdleState = LL_TIM_OCIDLESTATE_LOW;
TIM_OC_InitStruct.OCNIdleState = LL_TIM_OCIDLESTATE_LOW;
LL_TIM_OC_Init(TIM15, LL_TIM_CHANNEL_CH1, &TIM_OC_InitStruct);
LL_TIM_OC_DisableFast(TIM15, LL_TIM_CHANNEL_CH1);
LL_TIM_SetTriggerInput(TIM15, LL_TIM_TS_ITR0);
LL_TIM_SetSlaveMode(TIM15, LL_TIM_SLAVEMODE_DISABLED);
LL_TIM_DisableIT_TRIG(TIM15);
LL_TIM_DisableDMAReq_TRIG(TIM15);
LL_TIM_SetTriggerOutput(TIM15, LL_TIM_TRGO_UPDATE);
LL_TIM_DisableMasterSlaveMode(TIM15);
TIM_BDTRInitStruct.OSSRState = LL_TIM_OSSR_DISABLE;
TIM_BDTRInitStruct.OSSIState = LL_TIM_OSSI_DISABLE;
TIM_BDTRInitStruct.LockLevel = LL_TIM_LOCKLEVEL_OFF;
TIM_BDTRInitStruct.DeadTime = 0;
TIM_BDTRInitStruct.BreakState = LL_TIM_BREAK_DISABLE;
TIM_BDTRInitStruct.BreakPolarity = LL_TIM_BREAK_POLARITY_HIGH;
TIM_BDTRInitStruct.AutomaticOutput = LL_TIM_AUTOMATICOUTPUT_DISABLE;
LL_TIM_BDTR_Init(TIM15, &TIM_BDTRInitStruct);
/* USER CODE BEGIN TIM15_Init 2 */
/* USER CODE END TIM15_Init 2 */
* Enable DMA controller clock
/* DMA controller clock enable */
__HAL_RCC_DMA2_CLK_ENABLE();
__HAL_RCC_DMA1_CLK_ENABLE();
/* DMA interrupt init */
/* DMA1_Channel1_IRQn interrupt configuration */
NVIC_SetPriority(DMA1_Channel1_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
NVIC_EnableIRQ(DMA1_Channel1_IRQn);
/* DMA2_Channel1_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Channel1_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(DMA2_Channel1_IRQn);
/* DMA2_Channel5_IRQn interrupt configuration */
NVIC_SetPriority(DMA2_Channel5_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
NVIC_EnableIRQ(DMA2_Channel5_IRQn);
* @brief GPIO Initialization Function
* @param None
* @retval None
/* GPIO Ports Clock Enable */
LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOE);
LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOB);
LL_GPIO_ResetOutputPin(GPIOB, LL_GPIO_PIN_2);
LL_GPIO_ResetOutputPin(GPIOE, LL_GPIO_PIN_8);
GPIO_InitStruct.Pin = LL_GPIO_PIN_2;
GPIO_InitStruct.Mode = LL_GPIO_MODE_OUTPUT;
GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_LOW;
GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
LL_GPIO_Init(GPIOB, &GPIO_InitStruct);
GPIO_InitStruct.Pin = LL_GPIO_PIN_8;
LL_GPIO_Init(GPIOE, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
adcFullConversionComplete = 1;
adcHalfConversionComplete = 1 ;
volatile uint32_t wait_loop_index = 0;
#if (USE_TIMEOUT == 1)
uint32_t Timeout = 0; /* Variable used for timeout management */
#endif /* USE_TIMEOUT */
if (LL_ADC_IsEnabled(ADC1) == 0)
/* Disable ADC deep power down (enabled by default after reset state) */
/* Enable ADC internal voltage regulator */
/* Delay for ADC internal voltage regulator stabilization. */
/* Compute number of CPU cycles to wait for, from delay in us. */
/* Note: Variable divided by 2 to compensate partially */
/* CPU processing cycles (depends on compilation optimization). */
/* Note: If system core clock frequency is below 200kHz, wait time */
/* is only a few CPU processing cycles. */
wait_loop_index = ((LL_ADC_DELAY_INTERNAL_REGUL_STAB_US * (SystemCoreClock / (100000 * 2))) / 10);
while(wait_loop_index != 0)
wait_loop_index--;
/* Run ADC self calibration */
LL_ADC_StartCalibration(ADC1, LL_ADC_SINGLE_ENDED);
/* Poll for ADC effectively calibrated */
Timeout = ADC_CALIBRATION_TIMEOUT_MS;
while (LL_ADC_IsCalibrationOnGoing(ADC1) != 0)
/* Check Systick counter flag to decrement the time-out value */
if (LL_SYSTICK_IsActiveCounterFlag())
if(Timeout-- == 0)
/* Time-out occurred. Set LED to blinking mode */
LED_Blinking(LED_BLINK_ERROR);
/* Delay between ADC end of calibration and ADC enable. */
wait_loop_index = (ADC_DELAY_CALIB_ENABLE_CPU_CYCLES >> 1);
wait_loop_index--;
/* Enable ADC */
LL_ADC_Enable(ADC1);
/* Poll for ADC ready to convert */
Timeout = ADC_ENABLE_TIMEOUT_MS;
while (LL_ADC_IsActiveFlag_ADRDY(ADC1) == 0)
if(Timeout-- == 0)
/* Enable DAC channel */
LL_DAC_Enable(DAC1, LL_DAC_CHANNEL_2);
/* Delay for DAC channel voltage settling time from DAC channel startup. */
wait_loop_index = ((LL_DAC_DELAY_STARTUP_VOLTAGE_SETTLING_US * (SystemCoreClock / (100000 * 2))) / 10);
wait_loop_index--;
//Data Length an address has to be configured before enabling the channel
LL_DMA_SetDataLength(DMA1, LL_DMA_CHANNEL_1, ADC_CONVERTED_DATA_BUFFER_SIZE);
LL_DMA_EnableIT_TC(DMA1,LL_DMA_CHANNEL_1);
//LL_DMA_EnableIT_HT(DMA1,LL_DMA_CHANNEL_1);
LL_DMA_ConfigAddresses(DMA1, LL_DMA_CHANNEL_1,LL_ADC_DMA_GetRegAddr(ADC1,LL_ADC_DMA_REG_REGULAR_DATA),(uint32_t)aADCxConvertedData, LL_DMA_DIRECTION_PERIPH_TO_MEMORY);
LL_DMA_EnableChannel(DMA1, LL_DMA_CHANNEL_1);
//DAC address must be configured and data length must be set before channel is enabled
LL_DMA_ConfigAddresses(DMA2,LL_DMA_CHANNEL_5,(uint32_t)&PlayBuff[0],LL_DAC_DMA_GetRegAddr(DAC1,LL_DAC_CHANNEL_2, LL_DAC_DMA_REG_DATA_12BITS_RIGHT_ALIGNED), LL_DMA_DIRECTION_MEMORY_TO_PERIPH );
LL_DMA_SetDataLength(DMA2, LL_DMA_CHANNEL_5, ADC_CONVERTED_DATA_BUFFER_SIZE);
//Transfer complete and half transfer complete interrupts are enabled
LL_DMA_EnableIT_TC(DMA2,LL_DMA_CHANNEL_5);
LL_DMA_EnableIT_TE(DMA2,LL_DMA_CHANNEL_5);
//Channel is enabled
LL_DMA_EnableChannel(DMA2,LL_DMA_CHANNEL_5);
/* Note: Disable ADC interruption that caused this error before entering in */
/* infinite loop below. */
/* Disable ADC group regular overrun interruption */
LL_ADC_DisableIT_OVR(ADC1);
/* Error from ADC */
void HAL_SAI_TxCpltCallback(SAI_HandleTypeDef *hsai)
/* NOTE : This function Should not be modified, when the callback is needed,
the HAL_SAI_TxCpltCallback could be implemented in the user file
UpdatePointer = ADC_CONVERTED_DATA_BUFFER_SIZE/2;
void HAL_SAI_TxHalfCpltCallback(SAI_HandleTypeDef *hsai)
the HAL_SAI_TxHalfCpltCallback could be implenetd in the user file
UpdatePointer = 0;
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(char *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
stm32l4xx_it.c
* @file stm32l4xx_it.c
* @brief Interrupt Service Routines.
* @attention
#include "main.h"
#include "stm32l4xx_it.h"
/* USER CODE BEGIN TD */
/* USER CODE END TD */
extern void AdcDmaTransferComplete_Callback();
extern void AdcDmaTransferHalf_Callback();
extern void AdcGrpRegularOverrunError_Callback(void);
/* External variables --------------------------------------------------------*/
extern DMA_HandleTypeDef hdma_sai1_a;
/* USER CODE BEGIN EV */
/* USER CODE END EV */
/* Cortex-M4 Processor Interruption and Exception Handlers */
* @brief This function handles Non maskable interrupt.
void NMI_Handler(void)
/* USER CODE BEGIN NonMaskableInt_IRQn 0 */
/* USER CODE END NonMaskableInt_IRQn 0 */
/* USER CODE BEGIN NonMaskableInt_IRQn 1 */
/* USER CODE END NonMaskableInt_IRQn 1 */
* @brief This function handles Hard fault interrupt.
void HardFault_Handler(void)
/* USER CODE BEGIN HardFault_IRQn 0 */
/* USER CODE END HardFault_IRQn 0 */
while (1)
/* USER CODE BEGIN W1_HardFault_IRQn 0 */
/* USER CODE END W1_HardFault_IRQn 0 */
* @brief This function handles Memory management fault.
void MemManage_Handler(void)
/* USER CODE BEGIN MemoryManagement_IRQn 0 */
/* USER CODE END MemoryManagement_IRQn 0 */
while (1)
/* USER CODE BEGIN W1_MemoryManagement_IRQn 0 */
/* USER CODE END W1_MemoryManagement_IRQn 0 */
* @brief This function handles Prefetch fault, memory access fault.
void BusFault_Handler(void)
/* USER CODE BEGIN BusFault_IRQn 0 */
/* USER CODE END BusFault_IRQn 0 */
while (1)
/* USER CODE BEGIN W1_BusFault_IRQn 0 */
/* USER CODE END W1_BusFault_IRQn 0 */
* @brief This function handles Undefined instruction or illegal state.
void UsageFault_Handler(void)
/* USER CODE BEGIN UsageFault_IRQn 0 */
/* USER CODE END UsageFault_IRQn 0 */
while (1)
/* USER CODE BEGIN W1_UsageFault_IRQn 0 */
/* USER CODE END W1_UsageFault_IRQn 0 */
* @brief This function handles System service call via SWI instruction.
void SVC_Handler(void)
/* USER CODE BEGIN SVCall_IRQn 0 */
/* USER CODE END SVCall_IRQn 0 */
/* USER CODE BEGIN SVCall_IRQn 1 */
/* USER CODE END SVCall_IRQn 1 */
* @brief This function handles Debug monitor.
void DebugMon_Handler(void)
/* USER CODE BEGIN DebugMonitor_IRQn 0 */
/* USER CODE END DebugMonitor_IRQn 0 */
/* USER CODE BEGIN DebugMonitor_IRQn 1 */
/* USER CODE END DebugMonitor_IRQn 1 */
* @brief This function handles Pendable request for system service.
void PendSV_Handler(void)
/* USER CODE BEGIN PendSV_IRQn 0 */
/* USER CODE END PendSV_IRQn 0 */
/* USER CODE BEGIN PendSV_IRQn 1 */
/* USER CODE END PendSV_IRQn 1 */
* @brief This function handles System tick timer.
void SysTick_Handler(void)
/* USER CODE BEGIN SysTick_IRQn 0 */
/* USER CODE END SysTick_IRQn 0 */
HAL_IncTick();
/* USER CODE BEGIN SysTick_IRQn 1 */
/* USER CODE END SysTick_IRQn 1 */
/* STM32L4xx Peripheral Interrupt Handlers */
/* Add here the Interrupt Handlers for the used peripherals. */
/* For the available peripheral interrupt handler names, */
/* please refer to the startup file (startup_stm32l4xx.s). */
* @brief This function handles DMA1 channel1 global interrupt.
void DMA1_Channel1_IRQHandler(void)
/* USER CODE BEGIN DMA1_Channel1_IRQn 0 */
if(LL_DMA_IsActiveFlag_TC1(DMA1) == 1)
/* Clear flag DMA transfer complete */
LL_DMA_ClearFlag_TC1(DMA1);
/* Call interruption treatment function */
/* USER CODE END DMA1_Channel1_IRQn 0 */
/* USER CODE BEGIN DMA1_Channel1_IRQn 1 */
/* USER CODE END DMA1_Channel1_IRQn 1 */
* @brief This function handles ADC1 and ADC2 interrupts.
void ADC1_2_IRQHandler(void)
/* USER CODE BEGIN ADC1_2_IRQn 0 */
if(LL_ADC_IsActiveFlag_OVR(ADC1) != 0)
/* Clear flag ADC group regular overrun */
LL_ADC_ClearFlag_OVR(ADC1);
AdcGrpRegularOverrunError_Callback();
/* USER CODE END ADC1_2_IRQn 0 */
/* USER CODE BEGIN ADC1_2_IRQn 1 */
/* USER CODE END ADC1_2_IRQn 1 */
* @brief This function handles DMA2 channel1 global interrupt.
void DMA2_Channel1_IRQHandler(void)
/* USER CODE BEGIN DMA2_Channel1_IRQn 0 */
/* USER CODE END DMA2_Channel1_IRQn 0 */
HAL_DMA_IRQHandler(&hdma_sai1_a);
/* USER CODE BEGIN DMA2_Channel1_IRQn 1 */
/* USER CODE END DMA2_Channel1_IRQn 1 */
* @brief This function handles DMA2 channel5 global interrupt.
void DMA2_Channel5_IRQHandler(void)
/* USER CODE BEGIN DMA2_Channel5_IRQn 0 */
if(LL_DMA_IsActiveFlag_TC5(DMA2) == 1)
LL_DMA_DisableChannel(DMA2,LL_DMA_CHANNEL_5);
LL_DMA_ClearFlag_TC5(DMA2);
DMA2_Channel5->CNDTR = ADC_CONVERTED_DATA_BUFFER_SIZE;
if(LL_DMA_IsActiveFlag_TE5(DMA2) == 1)
LL_GPIO_SetOutputPin(GPIOB,LL_GPIO_PIN_2);
/* USER CODE END DMA2_Channel5_IRQn 0 */
/* USER CODE BEGIN DMA2_Channel5_IRQn 1 */
/* USER CODE END DMA2_Channel5_IRQn 1 */
  • but I don't think anyone is going to plough through all that!
    What have you done to find the source of the problem(s)?
    You've mentioned a number of processes going on in your code - what have you done to make sure each one is working in isolation?
    Have you started with ST's examples to make sure you are using the peripherals correctly?
    What do you mean by that?
    "DSO" usually means "Digital Storage Oscilloscope".
    Again, what do you mean by that?
