I'm using the FriendlyARM Tiny210 kit (Samsung S5PV210 ARM Cortex-A8 processor).We have loaded the OS Linux to our kit.
I have tested simple programs like led and buttons...Now, I have to test the UART program between the tiny210 and my PC, but I didn't find any test program dealing with the UART in Linux.
Could anyone managed to make the UART program working,help me for this?
Regards,
Hello and welcome,
What would you like to do with your UART?
You could use it as a simple terminal to input/output text: the PC would be the terminal client and you could run commands on the Linux board this way... Just an idea.
You may be able to start a login process on the UART by uncommenting a 'getty' entry in the /etc/inittab file and connecting to the UART using a terminal program on your PC such as Putty.
omda, shall we close the question then? Without answer, we will consider the subject addressed...
View all questions in Embedded forum
