Hi.
I try to Use LZ4 Algorithm to comperes and decompress data. I want to use LZ4_compressHC function. this function don't work. if know that problem from calloc(1,s) function. "s" is a struct in library. I use STM32F407VGT MCU. All code are below:
char des[400];char des2[400];int res1;int res2;
int main()
sprintf(des,"This is test. just one statement write to test this function"); res2 = LZ4_compressHC((des),(des2), sizeof("This is test. just one statement write to test this function"));
int LZ4_compressHC(const char* source, char* dest, int inputSize){ void* ctx = LZ4_createHC(source); int result; if (ctx==NULL) return 0; result = LZ4HC_compress_generic (ctx, source, dest, inputSize, 0, noLimit); LZ4_freeHC(ctx); return result; }
void* LZ4_createHC (const char* inputBuffer){ void* hc4 = ALLOCATOR(sizeof(LZ4HC_Data_Structure)); LZ4_initHC ((LZ4HC_Data_Structure*)hc4, (const BYTE*)inputBuffer); return hc4;}
#define ALLOCATOR(s) calloc(1,s)
When " void* hc4 = ALLOCATOR(sizeof(LZ4HC_Data_Structure));" executed the output value is zero (hc4 = 0).
I try to solve it. sizeof(LZ4HC_Data_Structure) = 262160.
typedef struct { const BYTE* inputBuffer; const BYTE* base; const BYTE* end; HTYPE hashTable[HASHTABLESIZE]; U16 chainTable[MAXD]; const BYTE* nextToUpdate;} LZ4HC_Data_Structure;
why this very big? bigger than SRAM?
View all questions in Embedded forum
